Transfer belts for the C550 series models are normally replaced by technicians. If you order the belt to install yourself, you turn off main power, open right side cover, locate guide plate under current belt, loosen thumb screw and remove plate, remove 2 screws securing the belt locks, remove front cable support on right side cover to lower cover, then pull belt out right side of machine. Install new belt in reverse order.
I would recommend a trained technician as the belts can become easily damaged.
SOURCE: konika minolta
CDC## Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
