Question about Karcher Garden
Water nozzle sprays only with thin jet of water-water will not fan out.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
CLR
BUY SOME CLEAN OUT THE HEAD REINSTALL HEAD USE AS PREFERED
also check you are ajusting the head right
failing that buy a new head
Posted on Jul 27, 2009
    President:
  • 583 Answers
Is the thin jet at high pressure?if so the nozzle has a larger hole andwill deliver more water which in turn cleans heavey dirt better if you want a mist spray,which is better for windows etc you may need a smaller nozzle
My bissel has stopped spraying water
locate nozzle where water sprays out and probe with a thin wire (like a bear twist tie wire) to unplug hole
Jan 18, 2016 | Vacuums
My rug doctor will not spray out water
check your spray jets are not blocked but also check your small pump is working & operating that spray the water out of the nozzles
Sep 01, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
The water is not coming out from water hose
Check that the nozzle jet is not clogged. To do this removed (unscrew) the nozzle at the end of your wand. Squeeze the handle. If water sprays out then your jet nozzle is clogged/corroded and either needs to be cleaned or replaced. This happens sometimes if you leave the wand sitting for several months with water still in the line.
Aug 09, 2014 | Daimer XTREME POWER XTREME POWER XPH-5900I...
Window washers not working wipers work but wash
first make sure that the bottle is full of water, if not sprayed clean the water nozzles by thin tool .
Dec 28, 2010 | 2005 Renault R5
Water spray not working
I got a thin needle and gently made a hole through the centre of the nozzle - where the water would usually come out. That cleaned the scum build up out of it and it's working fine again. My nozzle does seem to look like its going into the iron but perhaps it's to get the correct angle of spray onto the clothes.
Feb 13, 2010 | Sunbeam Irons
The dishwasher is not cleaning and leaving a white film on the glasses
You got hard water. Get a water softner system or use jet dri in your dishwasher. Also, check to see if the spray nozzles are clogged which occurs when you got hard water. The dishes won't clean if the spray nozzles are clogged.
Feb 04, 2010 | Dishwashers
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
The rear window water jet is not spraying water
you dont have to dismantle anything.simply get a thin sowing needle and put the pointed end into the small hole in the middle of the spray jet keep trying until until it clears;the little ball jet will move; again useing the needle move the ball back to point at screen ,hope this solves your problem.adrian
Feb 16, 2009 | 2006 BMW Mini
Jet spray nozzle not spraying water.
If no water is coming out at all, it might be that the inlet filter is clogged or the Est. time shows the code IE. To clean out the inlet filters, unplug the washer, turn off the water, open the valves, take a filter cap thing and try rinsing it out. To put it back to operational use, reverse the steps above.
Mar 26, 2008 | LG WM2688HWM TROMM SteamWasher
Garden Logo
190 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
