SOURCE: 1984 VT 500 C Shadow: 1983 honda shadow -starts and runs, seems to miss ...
The fuel filter is in the tank on the petcock and is self cleaning. I suspect you have bad spark plug caps on your bike the cap is part of the wire. If you remove the wire and take a reading with an ohm meter, the cap should read 5000 ohms . Anything above or below and you should replace the cap. This is probably causing the slight miss.
SOURCE: Jeg har glemt mit ecuritycode på min Nokia
If you've lost the security code and you notice some software problems, I would recommend you to get it flashed (installing new operating system) from a Service Center or from a Nokia Mobile Repairing shop. If there's software problem, resetting the phone will not help. You can flash it for yourself, but no one will recommend since buying the software and hardware will cost you more than the price of buying a new handset.
You should also that once the handset is flashed, everything saved on the phone will be lost and will never be retrievable.
If you want to try it yourself without the dedicated hardware and software, you can use Nokia Updater. Open this link (click here), [open the link and click the green "download" button to download the updater, nowhere else and nothing else] and download the updater application, follow the instructions on the page. Be careful with this, if this fails or the process is interrupted you'll end up with a dead set. You'll need your usb cable (if nokia pc suite is installed on your system, please uninstall it before you install this updater). Connect the phone using the usb cable to the computer and select "Nokia Mode". Run the program and follow the instructions. If you need further help, let me know.
[Note: If the process is successful, your phone will be unlocked and will be updated.]
Good luck.
Thanks for using FixYa.
