Question about Fisher and Paykel GWL11 Top Load Washer
Stuck on spin
My fisher paykel washing machine - 4.5 kg 7 yrs old is stuck on spin cycle and smells like something is burning. It is full of water and clothes.Help??
  • 145 Answers
With all do respect to Parky16, I'm not sure you know what a Fisher & Paykel unit is.
It sounds like you have a drain pump problem. You will need to get the water out. With a shop vac or something. Tilt the unit back on a milk crate, paint can or pull it out from the wall far enough so it will not fall down.
Looking up from the bottom on the left front side you should see a small pump. If it has been out of balance or has sucked something up in it the fan blade may be stopped. If not you should be able to freely turn this blade. If you can't turn it you have and internal clog.
If you get this far and don't want to call a repairman out let me know.
jim
Posted on Jul 27, 2009
  • 744 Answers
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
thank u
rate me!!
Hello I have a Fisher and paykel 7.5g smart drive excellence washing machine it doesn't spin and I can smell something burning.thanku Kelly
Has it drained the water out. It will not spin until completely empty. If it is not draining then Iwould say the burning smell is the drain pump overheating. Do not try to run it like that as the drain pump will short out the main control board eventually. Bail the water out by hand, tip the machine back against the wall and check the pump on the front right side of bowl. Replace the pump.
Jan 04, 2017 | Fisher and Paykel Washing Machines
Hi my MW512 Fisher Paykel doesn't spin properly washing still comes out with water still on
could be something stopping the pump from working,, the water control is leaking allowing water to come in while spinning, outlet hose from pump blocked/kinked
and not reaching full spinning speed ( overloaded wash)
May 06, 2016 | Fisher Washing Machines
Machine stops when gets to the spin cycle- last time was a hair clip stuck in pump. How do I get into the pump to get it out myself? Is a fisher and paykel smart drive about 9 yrs old.
Hi just read your posting.Is the machine draining any of the water?If it is not draining then bail some of the water out with a small bucket or pot, just enough so you can look under the machine without it leaking everywhere.Now when you are looking under the machine look to the front right and you will see a red or black fan.This is your pump.Turn the fan clockwise and anticlockwise a few times to loosen it if it is jammed.The fan should turn freely.If the pump turns freely then put the machine back on its feet and select a spin cycle and push start.The machine should now drain the water and then it will spin.Please reply on how you got on or if the machine still does not drain.Looking forward to your reply.
Jul 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
At spin cycle pump only runs for 3 seconds then stops
Sounds like the pump motor is overheating. Probably need a new one.
Feb 18, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing machine
motor is starting to wear out ,replace it .
Oct 01, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
210 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
