Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Water won't drain. It is not the sink air filter. Drain line goes into a disposal
  • 744 Answers
Hi..
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace thewater valve, the dispenser solenoid, or the whole dispenser assembly.
thank u
rate me!!
Posted on Jul 27, 2009
I have a Badger 5xp & a double sink. When I turn the disposal on I get a small eruption of water, air and disposed of debris from the other drain.
Take apart the tubular drain pipes beneath sink and clean out everything.
Take photos before removing pipes so parts go back together easily.
Loosen 2 nuts on trap, and trap falls loose.
Remove 2 bolts/screws and remove tailpiece from side of disposal.
Then run snake down drain line leading away from sink to make sure blockage is removed.
I wrote ez disposal steps that give tips on reconnecting tubular drain pipes:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Sep 24, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Newer Maytag dishwasher smells really bad inside
This problem can normally be fixed very simply and you can do it yourself.
1. There is a flexible drain line that goes from dishwasher to the sink drain line or garbage disposer.
2 You will find this flexible drain underneath the kitchen sink.
3. Make sure that the flexible dishwasher drain line goes up above the sinks lower portion of the sink basin and then comes back down into the sinks drain line or grabage disposer. The dishwasher flexible drain line must go above the bottom of sink basin like an upside down u shape, it will act as a upside down p-trap that you see under the sink in the sink drainline.
4. Once you have the flexible dishwasher drain line in this configuration (upside down U shape or p-trap) it will prevent air from leaking out of the dishwasher as the smell you are smelling is coming from the drian line.
5. You should also look inside the bottom of dishwasherr to make sure the drain screen is not clogged up.
Sep 08, 2011 | Dishwashers
My model DU810swkqo dishwasher will not drain completely [leaves about a couple of qts of water in the bottom after cycle.It has started dripping water out the bottom of the door.Can or does it need drain...
Hello
If the water won't drain from the dishwasher, first manually remove as much water as possible and then check the sump area for paper or any other large object. Make sure the door is properly latched. The pump will not drain if the door is not latched properly. Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
A cup or so of water in the sump area of your dishwasher is normal. It is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it's possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn't turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Aug 06, 2011 | Dishwashers
My dishwasher didn't drain the water out on the end of the clicle? What could be the problem?
Hello, Thank You for using FixYa. I will be helping you today.I would start where your drain line connects to the house drain,This is where most blocked drains happen. Disconnect the drain line and put it in a bucket and try to drain the dishwasher. Chances are its blocked somewhere you just have to find it.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Microwave Ovens
Water isn't draining.
Thanks for contacting fixya.com
Nov 11, 2009 | GE Nautilus 24" Built-in Dishwasher
Ge dishwasher water backs in when not running after it is empty? Water line to drain is connect to garbage disposel. if i still have problem would like phone to talk to someone thanks
You need to install an air-break to prevent dirty water from entering into the dishwasher.
These are typically installed on the flange of the sink and provides a positive break in the drain line from the dishwasher going into the disposal drain port, thus preventing back flow.
You can get these at any big box or hardware store in the plumbing section. Normaly, these are easy to install with some basic tools, unless you have stone countertops and an undermount sink. In that case, you'll need to install the air gap fixture under the countertop at the highest point possible, unless you want to go to the trouble and expense of having a custom hole cut into the countertop (both costly and not very attractive either).
With an air gap connector (back-flow preventer) installed on the drain line, you'll no longer have sink water able to flow into the dishwasher.
If this was a new dishwasher installation done by a paid professional, you need to contact them, as they did NOT do it properly and violated universal plumbing code by not installing an air gap on the dishwasher drain/discharge line.
If is was a self installation, you should read the installation instructions that came with the dishwasher, as it specificially addresses this issue. If a buddy helped, you might want to find a smarter buddy (kidding). If pre-existing condition, you ncan resolve the problem as I've described above with a little time and not much cost for the parts needed.
Hope you find this Very Helpful and best regards!
Aug 19, 2009 | Dishwashers
Water won't drain from my hot point dishwasher
Your drain/waste line under the sink is clogged with grease and soap scum.
Remove the P-trap and connecting drain lines, route out the drain and lines.
If you have a air gap mounted on the sink, clean that too.
Apr 02, 2009 | Hotpoint 24 in. HDA3740G Stainless Steel...
Dble sink, one with the garbage disp. won't drain standing water
It's a drain clog within the disposal. Try a drain cleaner, if no luck, you will likely need to replace it.
Feb 18, 2009 | GE 24 in. Profile PDW7800 Built-in...
Should the drain tube be looped or can it be pulled down for extra length
If the drain line goes into an air-gap on the top of your sink than it can be pulled down. If it goes directly into your garbage disposal then it really should be looped a bit higher than the bottom of your sink incase your sink gets stopped up the water will not flood back into the dishwasher. Some models come with a "check valve" on the end of the drain line (it's plastic and is about 2" long) these prevent water from draining back into machine and potentially flooding your nice floors.
Jul 21, 2008 | Maytag Dishwashers
Too much water after washing in bottom of dishwasher
Look under sink were drain line connects to drain.Make sure you have air gap in drain line.Meaning take the drain hose and tie it up high above drain were it goes into disposer or pipe.Most of the time I tie to underside of countertop
Apr 23, 2008 | Dishwashers
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
460 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
