Question about DeLonghi 9707 Oil Filled Radiator Heater
Wires have come off inside creda 9 fin oil heater
Heater has 2 control knobs . one has the watts. 600/900/1500, the other one has numbers from 1-5. it also has a red and an orange light.the earth which is the black wire has come off. there is also a blue wire, a brown wire and a blue and red wire together has also come off. any ideas anyone
  • 3,600 Answers
I have one and can tell you what the colorsare and how they are connected e-mail me at b123153h@yahoo.com so I can send you a picture later today or tonight so you can see how they are hooked up.
Posted on Jul 27, 2009
Need 4 Creda stove top range burners that are 7.25 inches round with 2 sides being square on each burner.
Creda Cooktop Product Support ' ManualsOnline.com
kitchen.manualsonline.com/support/creda/cooktop/
my gas cooktop was continually clicking and smoke ... i am looking for the manual fora creda colonial t ... Creda glass cooktop GH100, need a burner ignition.
Creda Spares, Parts & Accessories
www.4creda.co.uk/
We have parts for the full range of Creda models, so we're sure to have the part you ... Get the best performance from your Creda cooker hood with our range of ... fan oven elements, replacement control knobs, door gaskets and oven hinges.
CREDA GAS Cook Top Cooktop 4 Burner White 30" x 20 ...
bellingham.craigslist.org/app/5414687535.html Craigslist Inc.2 days ago - CREDA GAS Cook Top Cooktop 4 Burner White 30" x 20" HIGH ... make / manufacturer: CREDA ... The grates have some cosmetic chipping.
Jan 25, 2016 | Creda Kitchen Ranges
How can we ignite the pilot switch
The directions are on the inside cover of the water heater as well as on the paperwork you received with the unit.
If you have none of these, get the make and model number of the unit and look it up on the internet.
General directions to light a gas appliance:
1.Turn the switch to, "Off"
2.Remove the 2 panels at the base of the unit.
3 Identify the pilot device.
4.Get a long lighter or match on a stick that reaches the pilot.
5.Turn the gas knob to the, "Pilot" position
6.Light the match and put it next to the pilot while pressing down the knob
7. Keep the knob pressed for about 45 seconds after the pilot lights
8. Let go of the knob so it's in the, "up" position
9. Turn the knob to the, "On" position
-the water heater should fire up in under a minute.
10. Put the metal panels back into position.
Jul 14, 2014 | Honeywell VR8200C6008
Need a wiring diagram for rheem electric water 50 gallon 2007 model
1) Copy following links for standard wiring that applies to all brands electric water heater: wire colors vary, and do not matter.
You probably have ordinary residential non-simultaneous water heater.
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
2) Look at tank label.
Typical label will show number of elements (upper and lower)
And give wattage for each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html#label
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
Notice also total connected watts.
If total connected watts is same as individual upper or lower element watts, then you have ordinary residential non-simultaneous tank.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 07, 2013 | Water Heaters
How do you turn on a comfort zone cz7007? has a knob that turns up to 7 and 2 red switches right next to each other.
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Sep 24, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
OUR WATER HEATER IS BLOWING FUSES ..
1) Turn off power before touching water heater that is shorting or wet or was flooded.
2) Circuit breakers & fuses blow because of heat. A short will cause heat. Tighten screws on terminals inside box, listen for crackling sound/burning smell from loose-fitting parts.
3) Easy test for circuit breakers: move water heater wires to another same-size breaker. If same-size does not blow, then problem is breaker.
4) A short between fuse box and water heater could be gnawed electrical wire. Inspect wire.
5) Wires have size markings. 5500 watt water heater needs #10 wire. 4500 watt water heater needs #10 wire but can work with smaller #12 if distance is not long. See label on side of heater for wattage, voltage, etc. Element wattage is water heater wattage even with 2 elements.
6) Short inside water heater can be elements or thermostat. Open covers and inspect parts for burning. Screws should be very tight against copper wire. Sediment could fill bottom of water heater cause lower element to short.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Sep 16, 2010 | Little Giant Water Heaters
I would like to know how much is this heater minimum watts? Model: 6507L
with one switch on its 700 watts, second switch is 800 watts, thats 1500 total. even though a 14-2 wire could support this ...I would recommend a 12-2 wire with a 20 amp breaker
Mar 26, 2009 | DeLonghi 6507L Oil Filled Radiator Heater
Actual output on settings
MODEL DELONGHI TRD0820ER 2KW OIL FILLED RADIATOR
YOU HAVE THREE SETTINGS
1. 900 WATTS
2. 1.1 KW 1,000 WATTS WHICH IS ABOUT 1.096 WATT
3. 2.0 KW 2,000 WATTS
Nov 25, 2008 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Vulcan oil heater
1. Check electricity is on.
2. Check oil is in the tank and valve turned on.
3. Switch the fan off at the bottom left hand corner.
4. Switch oil knob to No.1.
5. Set Air knob to No.3.
6. Operate re set button (right hand corner of heater under settings dial). Either press in until it clicks or if the pull out version pull out until it clicks.
Wait - ignition should take place in a few minutes and flames will appear on the left of the burner under the radiants.
You should get occasional yellow crests above the pure blue flame just visible below the top row of burner holes under the radiants.
After the red warning light goes out you can adjust to higher settings.
The radiants do not glow on low setting.
You can adjust the heater on to higher settings but this should be done gradually - no more than 2 settings at a time.
Some warnings:
* The unit must be correctly earthed.
* Do not use anything except heater oil.
* Never attempt to re-light the heater when it is hot.
* If the red light does not appear when the oil knob is switched on, immediately turn the oil knob off. Reasons include: Heater is too hot; Electric plug turned off; failure of ignition system.
Good luck - no responsibility taken for the advice (but it is largely copied from my Vulcan heaters instruction manual which I still have (installed in 1967).
Mar 26, 2008 | Heating & Cooling
Operating instructions for creda storage heaters
how do you regulate the heat from creda storage heaters model No 79163 /79151 /79141 they have 2 dials on each heater,I was told the dial on the right turn up to 6 its highest point & the left dial to its lowest number 1 .But i got up this morning & its like a sauna
Jan 03, 2008 | Heating & Cooling
DeLonghi 9707 Oil Filled Radiator Heater Logo
209 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
