Question about Sony Computers & Internet
Sony VA10 Wireless Keyboard problem entering text
When typing any letter, I get a combination of a letter and a number displayed.
    Sergeant:
    Novelist:
  • 192 Answers
There is no quick fix. If you have the updated software from the website for the wireless keyboard, then your keyboard is defective and needs to be replaced.
Posted on Jul 27, 2009
When texting how to inter mix letters with numbers?
When you are on the letters virtual keyboard and want to enter a number or a symbol, tap on the box marked '123' or '123Sym'. That brings up the numbers+symbols virtual keyboard. After entering the number(s) or symbol(s), tap on the box marked 'ABC'. That will bring back the letters virtual keyboard.
Dec 23, 2014 | LG 440G Black CePhone - TracFone 3G, 1.3...
How to get the sterling pound symbol in K120 logitech keyboard
Entering the following keystroke combination will result in the Pound Sterling sign being displayed:
While holding down the ALT key, enter 0163 (ALT+0163).
This is known ASCII Code. (Pronounced Ask-key.)
A complete list of all 256 character codes is available at http://www.ascii-code.com/ .
All manner of Latin-based characters are available. Check it out.
To use any ASCII Code, choose the "HTML Number" and substitute "ALT+0" for "&#".
In this case, the HTML Number is &#163, therefore when entering text, type ALT+0163 (NOTE: "ALT+" means "While holding down the ALT key, press and release each of the four digits in sequence, then release the ALT key.)
Hope this helps.
Sep 02, 2014 | Logitech K120 USB Keyboard
Wrong letters display when I type
Hi Check "Control Panel" > "Regional and Language Options" > "Keyboards and Languages" > "Change Keyboards". This brings up the "Text Services and Input Languages" dialog box in Vista (XP may be a slightly different path). This box will display (in the "Installed services" section) how many keyboard layouts are installed on your computer. If have more than just the "US" keyboard installed, there exists certain keyboard combinations with the "Ctrl" key that will automatically switch your keyboard layout from the default US to another one that is installed
Jun 13, 2012 | Logitech Illuminated Keyboard
I have a motorola v545 and want to turn off the predictive text help!
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None.
Text-Entry Methods:
iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it.
TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key.
TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key.
Text-Entry Modes:
Primary - You can set your Primary entry mode to any iTAP or TAP entry method.
Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode.
Numeric - Enter numbers by pressing the number keys.
Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select.
To set the text-entry mode or method:
  • From a text-entry screen, press Options.
  • Scroll to and select Entry Setup or Text Setup.
  • Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Nov 15, 2009 | Motorola Mobility RAZR V3
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
Keyboard will not work
Try this and see if this works for you. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Let me know if this works for you, if not let me know.
JimmyC
May 07, 2009 | UTStarcom Blitz Cell Phone
Wireless keyboard will not type numbers. Only the corresponding symbols will show up. The shift key is not down nor is it stuck down.
Although Shift key is not pressed down, maybe the electronics are messed up due to shock if you dropped the keyboard. Turn off Caps Lock, go to text editor of your choice and try to type numbers together with some letters. If you get big letters, then Shift button is pressed down.
In both cases, just to make sure, try your keyboard on some other computer and see if it works.
If you find out that Shift button is always pressed, than it is a hardware problem that may or may not be fixable.
Jan 15, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Unlock blacberry pearl 8100
hi there :-)
try this i havn't done this but my friend does now he uses any sim on his pearl.
Pearl instructions - Can be done without a sim card inserted
To Unlock:
1. While on the home screen, click the "blackberry key" on keyboard, then select "options".
2. Choose "Advanced Options".
3. Select "Sim Card"
4. Type m e p p 2 to display the dialog box asking for the unlock code
(Press the Alt + 2 key to get the number 2)
( you will not see text appear on screen while typing )
5. Input the SIM Unlock code
6. Press in the trackball in once
Finish :-)
peace!
Dec 09, 2007 | Nokia 1100
Computers & Internet Logo
89 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
