Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ice maker does not work at all.
The ice maker doesn't seem to be getting any electricity, when I hold the infrared sensor to on and turn the little screw deals it doesnt rotate the ice maker or turn on the water flow. Not sure how to trouble shoot it further and cant find any schematics or wiring diagrams to test for power. Thanks for your time. -Jamie
    Problem Solver:
  • 17 Answers
On these machines their is a thermostat that tells the ice maker that it is cool enough to turn on rotate and turn the waterflow on.Their are 2 different types of machines.Some machines pull cool air from the top of the machine downward in between the back of the machine and the wall and then out the bottom of the machine or even worse some machines pull cool air from the bottom of the machine upward in between the wall and the back of the machine and then out the top of the machine.The thermostate is either located on the bottom of the machine or on the back of the machine.You should clean all the dust bunnys and debrie from the back and bottom of the machine (make it look new).This adds to the airflow also sometimes when installing the machine people pull off the cardboard from the back of the machine this is usually at the bottom of the machine.If this has happened just cover it with some cardboard and some duck tape.You should be able to put a 4x4 inbetween the back of the machine and the wall.Do not stack or limit the stack of stuff on the top of the machine.The freezer should be in between 32 and 35 degrees this maters even if it is off a degree or 2 the machine may not work.It may take a little wile for the machine to cool down enough for the ice maker to kick on.A simple thermamitor would be nice for testing the temp.This is only one option and it may work or it may not but hey it is cheep
Posted on Jul 27, 2009
Igloo ICE102 FULL sensor is stuck on
Hello If the ice maker light is stuck on full, most likely the Infrared sensor may have shorted out due to water seeping into either the infrared emitter or receiver or both. It is an easy fix. It is best to replace both the infrared emitter and receiver diodes. You can find 2 terminal/lead infrared emitter and receiver diodes on ebay or your local electronics store for cheap. Please ask the guys at the store that they are spectrally matched to each other. You just need to remove the old ones inside the ice maker and replace them with the new ones from ebay by soldering them on. If you cannot do this then best to take it to a local electrical store to get them to replace these for you.
Feb 01, 2013 | Refrigerators
Ice maker has stopped making ice. Infa-red light on inside doesn't seem to be working
One of the causes of ice maker not producing ice is a bad solenoid valve allowing water to pass by and causing the water line to freeze inside the freezer. In other words, if the valve is not holding very well, it will allow water to pass in the line that supplies water to the ice maker. A small drip will ensue and slowly freeze in the line and eventually turn into an ice plug that will prevent water from filling the ice tray. Thawing out the freezer will not solve the problem, you will have to replace the solenoid valve.
P.S.Test the solenoid valve coil and disconnect the line from the valve to verify that it is not allowing water to pass when not energized. Test the infra red module according the manufacturer's instructions if you have them at hand. If the solenoid valve is good and the infrared sensor system is bad , replace it (Infrared system) . The ice maker should be the last part to consider for replacement at this time.
May 06, 2011 | Refrigerators
RF266ABPN French Door Firdge/freezer Ice maker sensor
I found David's solution very helpful and I'll just add to it. Take out the top freezer door-- it just slides out and up. I had a bunch of stuff on the little shelf on the actual door and I had to take some of it off first. The big bottom drawer stays on. The little foam piece was on the floor of the freezer so I picked that up and can see how the little sensor part fits into it. Next, I put a chair next to the open bottom drawer, sat on it and leaned back onto and into the big drawer. I had to torque my head to actually get right under the ice maker. I am 5'5" so I don't know the heck David did it! Anyway, there is a little "slot" next to the last ice cube mold closest to the door. This is where the foam piece goes in. The slot where this piece goes has some raised lines sticking out on each side-- I wouldn't call them brackets and the foam thing doesn't stay in well by itself. However, on the right side of the ice maker, near that last cube, is a little hook. So I slid foam piece up with the sensor tucked in, facing the ice cube mold. I wrapped the tail/wire around the bottom of the foam piece and also the hook, so that it kind of holds the foam piece up in there, kind of cradling it. That was my solution, we'll see if it works!
Sep 29, 2009 | Samsung RS2534 Side by Side Refrigerator
Whirlpool Refrigerator Icemaker not working
The receiver board has an eye on it (it receives the signal and it may need cleaning. A Q-tip should do. Close the spring loaded panel and insert Q-tip and wipe.
Sep 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker not making ice
If water is also not com out of dispenser then filter should be changed. If water dispenses but ice ice is not being made, the sensor arm or infrared sensor may be stuck or blocked. If sensor is OK then ice maker needs service.
Aug 25, 2009 | Kenmore 57029 Side by Side Refrigerator
Whirlpool GS6SHAXMQ Side by Side Refrigerator - Ice Maker Problem
This happened to me after i had to move the freezer and it was unplugged for a while. When it was plugged back in the ice maker would not work.
Assuming both the ice maker itself and the rear water AC solenoid switch are actually not broken and are functional, and you are getting water from front door dispenser, then check the inside supply tube (black) is not frozen and blocked. Check with q-tip or feel to see if frozen.
If supply tube is frozen, thaw by holding up small full clear glass of heated water placing the frozen tube into the heated water. The clear glass will allow you to see when ice slips out.
Next try resetting the freeze cycle. Turn off the ice maker switch, remove the maker by carefully disconnecting the inside power cord. You will need to remove the inside door flap. Rinse the maker with warm water, allow to come to room temp.
Re-install maker, connect power cord. Turn on ice maker switch. Make sure Infrared sensor is not blocked. Now wait for temp change and listen for water to fill tray. It took maybe ten minutes for me. You will be able to hear the water fill with the door closed.
Again, this assumes nothing is actually broken.
This worked for me. Good luck.
Jan 18, 2009 | Whirlpool GS6SHAXMQ Side by Side...
I need help fixing my ice maker on a samsung rs2533sw side by side. It froze over and I just removed all of the ice. I am not sure how to re-assemble the unit. ie. the small sensor tube and plastic shaped...
THE LITTLE SENSOR GOES UNDERNEITH THE ICE TRAYU IN THE FOAM RIGHT BY THE MAIN ICE MACHINE MOTOR. THERES TWO CLIPS THAT HOLD THE PLASTIC PIECE ON AND LETS THE SENSOR GET A TRY READING ON THE ICE TRAY.
Dec 21, 2008 | Samsung RS2534 Side by Side Refrigerator
Ice Maker Infrared light doesn't light
Each mold tray has a heating element that is turned on to free the ice cubes from the mold tray and allow them to fall into the ice bucket when the tray is rotated into harvest position. Sounds like that is not being turned on... or is defective..
Sep 18, 2008 | KitchenAid KSRG25FK Side by Side...
Fridge Freezer Ice maker problem
We have an Whirlpool side by side America fridge freezer. Water is not flowing into the ice-maker
Mar 31, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
303 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
