Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
1972 Seeburg, trouble opening back panel, buzzing volume sound...
How do you open the larger back panel up?
Constant buzzing sound coming from speakers, no control.
Will not pick up a record, but thinks it did and will spin.
Please someone help me.-ROB
  • Alan Hood May 11, 2010
    Hi Rob, What model of Seeburg do you own? Regards Alan Hood ami-man UK
    Scholar:
  • 195 Answers
Hi Rob,
When you open the front of the jukebox you will see on the rear of the jukebox is a lever that unlocks the rear door.
However if you have a problem with the sound the access to the amplifier is behind and above the keyboard, again there is a lever to open this access as well once you have opened the title door on the front of the jukebox.
Regards
Alan Hood
ami-man
UK
Posted on Aug 10, 2009
Buzzing from speakers
Audio output card has damaged. Replace it.
Oct 11, 2012 | Vizio Gallevia GV42LF 42 in. LCD...
Buzz sound when tv is on constant
Hello; If you have a plasma TV, is fairly common to hear buzz noises. They can be always there or intermittent. They can get louder as the screen gets brightest. If the buzz is noticeable when you are at normal volume setting, the buzz is excessive and a PCB probably needs replacing. These buzz noises are almost never a sign of failure or safety. LCD TV's can also buzz, but the same applies. John
Jan 27, 2011 | Televison & Video
How do I get rid of the constant buzzing sound coming from the back of my dynes. The only way I can get it to stop is to hit the mute button
The only thing you can do is if your on a cable box, make sure the volume on the box is all the way up. Then adjust the volume on the tv according to your likening. If you don't have a cable box then I would contact your local service company because you have an issue with the set.
Nov 10, 2010 | Dynex DX-LCD32-09 LCD TV
Sony SA-VA10 Shelf System Powered Monitor Speakers. Constant Buzz .. around 1K . .sounds like power supply. Not attenuated by increase in amp volume. Help
Secondly sounds like the power supply filter capacitor has gone bad. Write down the value off the label and purchase one at your local electronics parts place. It will only be two solder leads to unsolder and solder back. But first check the other place for that symptom, an open ground near the input jack going into the amplifier, or broken input wire/plug.
May 19, 2010 | Sony SA-VA10 Shelf System
Buzing sound
Usually this is a defective main board, if it's under warranty it's an easy onsite fix. Usually takes less than half an hour.
Aug 11, 2009 | Vizio VO47L 47 in. LCD TV
Audio buzzing
Check the cables because this sound comes when the polarity of wires interreact with each other.
May 07, 2009 | Vizio GV42L 42 in. LCD Television
Constant Buzz coming from SX-255r
Power source harmonics. Or its power supply regulation. Check also if input line is touching something.
Apr 03, 2009 | Pioneer SX-255R Receiver
CONSTANT BUZZING SOUND
A buzz in the sound can come from having your audio cables to close to the power cords. Or a problem with the cable box. A problem with the Ac power supply like a bad input filter can cause a buzz. If it changes when you turn the volume up and down it is not power supply. Hope some of this helps.. It is hard to be sure without hearing it
Mar 24, 2009 | Vizio L32 32 in. LCD HDTV
I want my music back!
Have you tried to raise the volume by double clicking on the speaker icon on your taskbar. This will open the play control panel where you can raise the volume.
If you do not see the speaker icon, go into your control panel and chose sounds and audio devices and raise the volume from that screen.
Mar 31, 2008 | Gateway 2520915 Keyboard
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
323 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
