Question about Acer Aspire™ T180 PC Desktop
I need to reset the display settings but i cant see what they say
My problem is that i messed with the display settings and now there black i can see all of the little icons for internet and stuff like that and i can also see my background but everything else is black and all the words are also black so i cant fix the display settings cause i can see them
  • 40 Answers
Press the ok button of your monitor,
it would display a window, use the two other buttons on the monitor(excluding the power button) and move to "adjust color" and press the ok button and try changing the color selected.
Posted on Jul 27, 2009
    Sergeant:
    Novelist:
  • 192 Answers
It's a simple fix. Reboot your computer and press the F8 key repeatedly until you come to a boot menu. Select Safe Mode. This will take you into Windows at a default of 640x480 resolution. Adjust the settings according to the monitor and lower them to what you had them before you did the changes.
Another method is when you are at the boot menu selection, you can select safe mode with command prompt.
Type c:\windows\system32\restore\rstrui.exe for windows xp to use the system restore and rollback windows to when it was working properly.
For windows vista type:
c:\windows\system32\rstrui.exe
Resetting date on Fujifilm S4400
If you cant find date on Menu would reset camera setting to Default and start all over.
Sep 20, 2012 | Fujifilm FinePix S4400 Digital Camera,...
My Camera will turn on but the display is black. I took a picture to see if the light in the display was messed up but it is taking black pictures. My husband messed with the display settings and it worked...
Reset your gadget to factory defaults........ If the problem is due to wrong settings then it will solve it. And If not, then their could be a mechanical problem so, get it serviced................
May 03, 2010 | Samsung BL103 Digital Camera
Cannot get screen resolution 1280x 1024 pixels
Make sure your screen refresh rate isn't set higher than 75Hz. It's in Display Settings or Screen Resolution depending on what version of Windows you use. You may have to go into advanced settings and look in the Monitor section to find it.
There should also be a way to reset the monitor using its built-in controls just in case something got messed up.
Mar 14, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
How do I get the "change oil" message off my 2008 f 450 superduty?
Message center cluster
#1 press and release setup button until mess. cntr. displays"press reset to begin system check"
#2press and release reset button until cntr. displays"hold reset if new oil"
#3press and hold reset button for 2 sec. and release oil life should read 100%
#4 center displays"setup menu hold reset"
base cluster
#1 press and release trip/reset button until mess. cntr. displays"setup menu hold reset"
#2press and hold trip/reset button 2 sec. until mess cntr. displays"reset for system check"
#3 press and hold trip/reset button 2sec. until mess. cntr. displays"oil life XX% reset if new"
#4 press and release trip/reset button until mess.cntr.displays"hold reset if new oil"
#5 press and hold trip/reset button for 2 sec.and release to reset to 100%
#6 mess. cntr. breifly displays oil change set to 100%.
HOPE THIS HELPS
Feb 10, 2010 | 2008 Ford F 250 Super Duty 4WD
Having a problem accessing my e mail from gmail, i was messing with the securtiy settings one day and it blocked the web site, can even use google, when i try to access my e mail it says it cant display...
Go back to the security settings, search around until you find reset defaults, it should be there some where. Hit that and it shoud solve your problem
Dec 29, 2009 | Computers & Internet
Changed display settings now they're all messed up
right click on desktop go to properties-setting resolution 1024x768 color setting 32bit apply and than ok
Aug 05, 2009 | HP Pavilion dv6000z Notebook
Sony Ericssion K 750 i 2 M.P. Camera
try to reset it to default settings, Menu/settings and on the general tab right at the bottom it says Master reset.
Mar 31, 2009 | Sony Ericsson K750i Cellular Phone
Hp laptop black screen but running in background
I have to know if you changed the display resolution settings. If so, boot the laptop to safe mode (tap the F8 key after you turn it on). Go to Start > Control Panel > Display and select the settings tab. Try changing the resolution to 1024 x 768 and see if that will bring everything back to good order.
Good luck, and feel free to rate this advice.
Mar 15, 2009 | HP Pavilion dv6000z Notebook
WRONG DISPLAY SETTING
Hold power button down for 15 seconds, the power botton on the front.
Mar 31, 2008 | Sony Playstation 3 (PS3) Console
Blacked out screen
Have you been messing with the actual backlight, or with the backlight settings through the player? In case you haven't messed it up, you might be able to reset it by resetting the firmware, use this link http://mpmaneurope.net/download.aspx?file_id=163 Good luck ;]
Jun 09, 2006 | MPMan MP-FUB26 MP3 Player
Acer Aspire™ T180 PC Desktop Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
