Question about Frigidaire Dishwashers
Base Cover is missing
I have a Frigidaire ''Precision Wash System'' Ultra Quiet II. At the bottom of the dish washer is a cover that hides all the wires underneath it. This cover is missing. Where can i get a replacement?
  • 1 more comment
  • apatterso730 Jul 27, 2009
    Where do i find the # on the dishwasher?
  • apatterso730 Jul 29, 2009
    Here is the Model# FDP635RFR3 Where would i find this part for my washer? Thanks!
    i'm at work now and i was about to call the 800 # but i don't have access on what i replied to you. I left the model # at home and i'm not able to see the model # i sent to you. Can you forward me that model#? Thanks!
  • 6,784 Answers
I assume you are referring to the Junction box cover, correct?
If so, please relay your model number so that i may direct you to the correct order page on-line please?
Posted on Jul 27, 2009
  • 2 more comments
  • Michael Masters
    Michael Masters Jul 27, 2009
    Model Number Locator Tips
    1. A zero in the model number might be the letter O.
    2. A lower case L might be a 1.
    3. Some models have 3 digits and a period first, like this 555.66666666
    Look for an aluminum tag--or a silver and white adhesive label in the locations illustrated below. The model number may be printed or stamped onto the tag and may be printed in different type sizes. NOTE: There may be partial model numbers on marketing stickers or in the owner's manual. These are often incomplete. For best results use the model number from the tag.
  • Michael Masters
    Michael Masters Jul 29, 2009
    Hi. I have done some extensive searching for this part, and came up with only one outlet part store that would sale it. it is available but, it is a SP(special order) situation. you will need to call the number below to request the special order procedure for the base cover that you seek. They will ask for the model number first, then just request the cover.
    The Repair Clinic----800-269-2609
  • Michael Masters
    The model number is FDP635RFR.
  • Michael Masters
    (( FDP635RFR3)), sry. i left the #3 off in the above post.
Why do my frigidaire ultra quiet ii does not dry?
Good Afternoon Friend,
I understand your Frigidaire dishwasher, model# FDB1050REC, is not drying your dishes. I also see you want to know which part needs to be replaced. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose and determine what exactly is causing your appliance to not dry the dishes. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
My dish washer is 4 years old and is not cleaning dishes or disolving soap. HO appears in the status window which my manuel says indicates a water heat delay. How can this water heat delay be repaired ? ...
The water heat delay indication could be caused by the fact that the heating element has failed so that the washer will not proceed with the wash program until the water is up to the correct temperature. You should be able to tell if the element is getting hot. You could try manually putting in hot water before the washer fills up with cold to see if the wash then proceeds.
Sep 22, 2010 | Frigidaire 24 in. PLD2850 Built-in...
I have a Whirlpool Quiet Partner II that used to
ok first prime the sink then put a table spoon of tang in dispensor then run the unit this will clean the dish washer
Jun 30, 2010 | Dishwashers
Trying to determine its age
Only from the manufacturer you can find. If you can note the Model No Sr. No of the machine, it is possible. If it is a discontinued model, it may not be possible.
May 20, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Won't turn on. Frigidaire, precision wash, ultra quiet 1
I have the same issue and it occurred around the same time as your post. Do you think there is a conspiracy? :-)
Feb 28, 2010 | Frigidaire 24 in. FDB126RB Built-in...
My diswasher is leaving a grimy film on all the dishes after they are run through the cycle, I'm wondering if it is because the dishwasher itself needs a cleaning and if so how do I clean it its a...
Go to you local Supermarket and purcase a bottle of disjwasher cleaner is about 8 bucks a bottle in some cases you may need to use two bottles I would buy 2 but use just one if it works save the other one for a future occasion.Follow all directions on bottle..Make sure you use it in an empty dishwasher and turn hot water tap on closest to dishawsher to make sure it is filling with hot water...You will be quite surprised at how clean your first load of dishes will look after the cleaning
Jan 23, 2010 | Frigidaire Precision Select 24" Tall Tub...
Water left in compartment
You need to elevate your dishwasher drain hose under the sink. The water going down your disposal side is running down the hose into the dishwasher.
Nov 05, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
Aug 30, 2009 | Frigidaire Dishwashers
Frigidaire ultra quiet I dishwasher
Sounds like the water may not be turned on to the dish washer.
The arm spins with water pressure
Oct 16, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwashers Logo
184 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
