Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Chamberlain whisper drive,door open by itself,Yellow light on
I have a whisper drive recently to find the door wide open by itself.Yellow light is on right sensor and green on another.
3 Suggested Answers
whirlwindsys
  • 18 Answers
SOURCE: Chamberlain Whisper garage door system that only closes 3/4...
One sensor should always be yellow, the other should be SOLID green.
If the lights are not consistently SOLID, you have a sensor issue.
TEST: If the door closes completely by pressing and holding down the wall pad button, you have a sensor problem.
Check to make sure the are aimed properly at each other.
Check the wire at the sensor and more importantly at the machine (If the wires are loose at the machine (terminals) it can cause this problem. Remember the machine does shake a lot.
If the wires are good, the sensors are aimed correctly, you have a sensor issue and need to loacte a replacement set.
Posted on Feb 20, 2009
  • 398 Answers
SOURCE: Chamberlain Whisper garage door closes 3/4 then pops open
check the wiring if its ok you need new sensors
Posted on Feb 26, 2009
My new installed garage door opener closes and opens right away
You have to adjust the safety pressure sensor. It is set to too light a pressure. Check your manual for the adjustment.
Mar 10, 2013 | Chamberlain 1/2-HP Whisper Drive Belt...
Chamberlain Power Drive / Whisper Drive My garage door starts to open and immediately reverses but continues to run. I had to release the cord to allow the chain to run its course before it would stop....
It sounds like the door is your problem.
Check the counter balance spring above the door. It is likely broken.
If the door cannot be operated manually, the garage door opener will not open it either. The machine is made to operate a door that works correctly. If the door is broken, the machine will not work either.
It also sounds like the opener gears may be worn out. That also occurs because the door required service.
Jan 02, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
My garage door will not open, the door gets close to the ground, then back up again. one sensor is green and other one yellow color. Please help me. My email- frooty2cute@yahoo.com
LUBE THE SPRINGS AND ROLLERS WITH WD40.
WATCH THE SENSOR LIGHTS TO SEE IF THEY GO OFF JUST BEFORE THE DOOR CLOSES. IF THIS IS THE PROBLEM EITHER ADJUST THE TRACK OR MOUNT THE SENSORS TO THE WALL INSTEAD.
IF THE SENSORS STAY LIT AND THE DOOR STILL REVERSES AFTER LUBE. ADJUST THE DOWN SENSITIVITY ABOUT 1/8 TURN AT A TIME (LESS SENSITIVE) ID YOU HAVE TO ADJUST THE SENSITIVITY MORE THAN 3/4 YOU WILL NEED TO CALL A PRO OUT TO CHECK THE PROBLEM.
HOPE THIS HELPS
Oct 19, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Upon pressing open/close button kitchen door the garage starts to close but then reopens after 3-4". one must then hold button until door is fully closed. what is remedy?
The problem is that your system does NOT "see" the safety "eyes" sensors. Make sure that your sensors are properly connected to the opener (both sensors should have lights on them, one amber and another green). If they do not, check the wiring and the connections at the opener itself.
Sep 09, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
How can I disconnect the motion detector on the Chamberlain 3/4 HPS Whisper Drive Plus Belt Drive Garage Door Opener with EverCharge
There is a button on the side of the wall-mounted remote. It has a pic of light bulb next to it. Press it once - the motion sensor is on and the lights will be on once it senses the motion; press it again and the motion sensor will be off.
Jul 19, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Feb 17, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
1,577 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
