Question about Kenmore Heating & Cooling
How to drain Kenmore Elite A 100 E air conditioner. It has a small plug at the very bottom but it doesn't really drain and water leaks out the bottom. Instruction booklet not clear.
SOURCE: We purchased a Whirlpool portable
Check to see if the drain is blocked by particles/debris of any type. Also make sure that the unit is level--as level as possible. I have my Whirlpool Portable AC in 4 inch bed risers so I can drain it really easily. I slip under a small low rise pan and drain it every two days or so when it is running. Mine leaked when I tried to incline it backwards to make it drain faster. As soon as I leveled the unit the leak stopped and water again came out the hose. These units must be kept level to prevent leaks so now I always do that.
Posted on Jun 20, 2009
soroka69
  • 3 Answers
SOURCE: kenmore air conditioner is leaking
Your A/C have to be tilted to the out side of the windows!!! It will drain it self to the sidewalk.
Do not set your A/C horizontally perfect!!!
It has to have tilt up to 15 degrees to the outside of a window.
Outside should be lower than in side.
Posted on Aug 19, 2009
SOURCE: air conditioner dripping water
im in exactly the same boat tomorrow im goin to tackle cleaning the compensatory drain its 3/4 pipe either a hoover hose pipe or air compressor il let u know how i get on
Posted on May 23, 2010
SOURCE: Kenmore Elite A120E Air Conditioner
I will need clarification on this, is it window air conditioner?
Posted on Aug 21, 2010
  • 4736 Answers
SOURCE: I have a Kenmore C120
Interestingly, your Kenmore Portable AC is manufactured by Delonghi. Occasionally, what you are experiencing happens when the humidity level is high and the air intake filter needs to be cleaned.
That also means that you will need to drain the tank, at least once.
You know where the drain plug is, so you can either carefully take it outside to drain or put a low sided container, capable of holding 1 1/2 quarts of water under the drain plug. If you drain it inside, turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to drain it.
Hope this helped you to solve the problem.
Posted on Jul 13, 2011
We have a Kenmore Elite 795 fridge. It is constantly leaking water from the bottom right corner of the unit onto the floor. There always seems to be a build up of ice at the bottom of the unit.
Usually the result of CONDENSATION due to eithr bad door seals allowing air and moister in to condensate. or a plugged or clogged evaporator drain line which causes water to back up and freeze or leak out the lowest point the bottom?
Mar 19, 2015 | Kenmore Refrigerators
I have a Kenmore C120 portable air conditioner. It is leaking water from the back bottom. There is a white drain but this unit is supposed to self evaporate. At least it did last year. Now it is leaking...
Jul 13, 2011 | Heating & Cooling
I have purchased a Kenmore Elite A100E floor model airconditioner and when it is running water pours out from where the wheel castors are connected underneath the unit??
This also happen to me and it means that your drain is clogged it needs to be cleaned out. Your grill in unit could be dirty and probably needs to be cleaned also.It is really simply but might sound complicated it's not and if it is not under warranty it would be cheaper to do it yourself. You need to take offf the sides and get a little flash light one of the sides have the drain hole and you get like a piece of wire or something like that, something thin to dig out what is clogging the hole & get a small dust brush or vacuum the dust from the grill and drain the air conditioner put the plug or stopper back in and put the sides back on and screw them into place and everything such be fine.
Jun 12, 2011 | Kenmore Heating & Cooling
My unit doesn't drain. isn't there a rear port or hole that water should drain from?
There is no drain on some of the newer ones,that plug into a 110 outlet.Look on the bottom of the case,to the rear of the unit.If it has a drain the case will have a small hole in it.
May 13, 2011 | Maytag M6Q10F2A Air Conditioner
My Kenmore Elite A100E has leaked water all over my hardwood floor. It's supposed to be bucketless. How do I drain it?
i have the 120e version and its doing the same so i cut a couple sticks stradeled them across a sturdy plastic tote and now i have a bucketless with a bucket that should take a couple days to fill
by the way what did sears say
Jul 16, 2010 | Kenmore Heating & Cooling
Water in Leaking in the Freezer
Hi, this sounds like a problem with a blocked drain. For full instructions on clearing the blockage from my tips click HERE if you have any other questions please feel free to comment. Mike
Dec 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Leaking Kenmore A100E
Take the unit apart and clean out the bottom with a water hose,clearing all the debre out of the unit.
Aug 30, 2009 | Heating & Cooling
My Air conditioner leaks water
All A/C units drain water and need a clear path to drain water.
If window unit the unit MUST lean to the outside so the condensation water can drain that direction and insure the drain hole is clear of debree.
If an indoor central a/c unit the drain must be clogged the unit is leaning away from drain or the pipe going to the drain is clogged somewhere as it exits house. Cant drain if doesn't have a clear path to do it's job. Doubt it's a problem with the brand.
Aug 02, 2009 | Kenmore Heating & Cooling
We purchased a Whirlpool portable air conditioner in 2005 from Best Buy. Near the end of last summer the air conditioner started leaking water. We started using it again this season and it is still...
Jun 09, 2008 | Whirlpool Heating & Cooling
Heating & Cooling Logo
1,017 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
