I think either the gasket has come off and the tension spring has separated from the hinge or the tension spring is broken. Information needed how to repair this
SOURCE: i need to reset my dishwasher but don't know how!!
bdw13 showing e4 & trying to empty when no water in it
SOURCE: broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs.
Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the
aid of springs. If the springs (or the cables that connect them
on some dishwashers) break, the door will drop open hard. The
door will also be heavier when closing. If the door drops open,
it may also bend the door hinges out of shape resulting in a door
that does not close properly and possibly leaks.
When replacing the springs or cables,
all of them should be replaced at the same time.
To access the door springs and cables
remove the lower panel located beneath the door. The panel is
usually held in place with two screws either above or below the
panel. It may be necessary to first open the door to the dishwasher
to get to the screws over the panel, then close the door to remove
the panel.
There are two common types of spring
assemblies. One type connects the springs from a hook on the dishwasher
cabinet of to a tang on the door hinge .
SOURCE: Hinges on Pavilion zv5000
Hinges are 2 seperate pieces that are attached to your LCD screen and then attached to the base of your laptop. I wouldn't be surprise that $160 is the repair cost. Hope this includes labour cost cuz its time consuming to open the laptop and take it about just to replace them.
You do this yourself by finding the same hinges on ebay and doing it yourself if you feel comfortable. If not leave it to a computer nerd who know how to.
SOURCE: Baumatic BDW13 14 dishwasher SHowing E3 Fault
I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
SOURCE: error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
