Problems with RCA TV screen
I have a television RCA big screen model P529375G. The problem is that our power went out several times last week. The last time it did and came back the TV screen was changed. THe picture seems to be stretched out past the parameters of the screen and it is also being stretched through the corners where vertical lines near the edges of the screen are being curved. There doesn't seem to be any means of fixing it through the TV's menu. Is there anything you can suggest to help?
THankyoU!
  • brange98 Dec 29, 2008
    I have a television RCA Model F32444. The picture seems to be stretched out past the parameters of the screen and it is also being stretched through the corners where vertical lines near the edges of the screen are being curved. There doesn't seem to be any means of fixing it through the TV's menu. Is there anything you can suggest to help?
jomaru
  • 337 Answers
SOURCE: Flickering Picture?
Your set might have a high voltage leak and that is the noise you hear when is showing the screen problem or even maybe an arking too ,either one is related to the high voltage and it can be dangerous,if you are familiar with tv service you can try to see where is arking and replace the part with an exact replacement but if the set has a leak you will not see it and is not safe to be close to it,if you are not too familiar be safe and call for assistance from a servicer.
Posted on Oct 27, 2006
  • 236 Answers
SOURCE: Sony FD Trinitron WEGA kv32fs120 32" picture too big/vertical arch...
Sounds like you have a problem with the high voltage regulation or the power supply. This condition is called "blooming" Stargazer
Posted on Aug 29, 2007
ameesh
  • 22 Answers
SOURCE: sony LCD tv
i guess its the old magnet problem maybe in fluke u or someone in your house had taken a magnet around your tv try fixing it with a magnet by moving the magnet again around the screen and using the same old technique by moving the magnet slowly on the defected area and then quickly taking it off
Posted on Nov 05, 2007
  • 31 Answers
SOURCE: 50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Posted on Mar 10, 2008
SOURCE: I HAVE A OLDER MODEL RCA HOME THEATER BIG SCREEN TV
I have the same tv at my place and I got Sears to come over and fix it. It cost me ~$90 for the initial visit then I ordered ~$140 part he recommended (voltage thing for crt) ordered and installed. He said that if that didn't work then he would have been able to return the part and it would have been the circuit board going out and that would have cost around $400 more. He said that if that were the case it wasn't worth it since you can buy one of these tvs used for around $500. The part he ordered worked on my tv and is doing fine.
I have an additional question though: is this tv HD ready for when all the signals change next year?
Posted on Apr 10, 2008
Rca hdtv 52inch will play fine then picture goes black but still has sound.. after a few mins.picture will come back on , and will play fine could last all day or may go out again in a few mins.
My tv is relatively new, but the bad thing is that I had an old; big screen tube type rca model; home theatre, that was heavier than a car, and it went out, due to the cracking and popping sound, off sometimes, and back on.
What is strange is the new tv now, the hdtv, light weight, about five years old, is doing the same thing. Actually, now, the power will not even come on. The lcd green light in the front goes on and off.
Take no offense, but I thought I would not have these problems anymore. What do you suggest?
Feb 16, 2010 | RCA HD52W59 HDTV Projection Television
My RCA big screen tv sound shuts off
This could be several different problems. You could have loose solder joints, bad capacitors, or the aodio ouput IC could be getting hot andf failing and needs to be replaced.
Jan 10, 2010 | RCA P61310 TV
It won't turn on. The TV has been intermitant for a about a week.
Hi.
Try first leaving the TV disconnected from power for several hours. Also test on a different main, eventually using an extension.
If the problems started intermittently last week, then there is probably a fault.
If there is no power at all it is a faulty power supply.
If the TV instead is in standby, then the set must be tested to find the fault.
Common faults may concern convergence, PSU, ballast board, control and signal I/O.
Here all parts for your set.
Oct 13, 2009 | RCA G27669 27" TV
Sony Trinitron won't power up
if the power went out all that may be bad is the fuse; follow the power cord inside the set and it will take you right to the glass fuse; these sets also had problems where the power supply in them fails--several parts get killed instantly--if this is the case---good advice would be to look for a new tv.
Aug 07, 2009 | Televison & Video
Power problem on a RCA big screen TV
Even with the tv turned off, the power supply is still active.It's supplying voltages to the microcontroler, that's why each time you press the power button on remote the tv respond by turning on. First check the power cord to be well connected in the power-bar and if it's ok...well the power supply is defective and due to the high risk of electric shock i suggest you to call a technicien.
P.S. I respond here because I don't know why our chat session got disconected.
Feb 01, 2008 | Televison & Video
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
Won't turn on
That is a shame a company like RCA will not stand behind thier products if the warranty just runs out. Were you offered an exteced warranty at the time of purchace. if so go back to the store and see if it is too late to buy one. Then next week call the servicer and say the TV went out. I have heard of this being done before. Good luck.. The problem with your TV set is most likely the power supply. unless yopu have electronic test equipment, this could cost you big bucks.
Mar 21, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
