Question about Cell Phones
Callers cannot hear me when i use my convoy 3
Person can't hear me sounds like in a drum?
could be your volume is a touch to loud ask person your talking to, to see if it sounds better as you lower the volume and ask him if he could lower his slightly . Hope this helps .
Jan 12, 2016 | Samsung Convoy 3 Mobile Phone - Gray...
I want to take off the ring silencer on convoy 3
I use Convoy 2. Go to "Setting" and select "Sounds settings".Select "Call Sounds" and select "Call ringtones". Then select "Call ringtones". Find "no ring" if you see it just select the ring tone you want and test the ring tone. I hope it is work for Convoy 3.
Sep 28, 2014 | Samsung Convoy Cell Phone
How to change language to english Samsung convoy 3
I have Convoy 2. To change the setting you press "menu" Usually center button on phone. Go to "Star" for settings. On Convoy 2 phone setting option 8, Press "OK"(center button), Select options 5 for language a press "OK" and select language. I hope Convoy 3 have the same menu.
Jun 17, 2014 | Samsung Convoy Cell Phone
What can i do if noone can hear me
WAT can I do if nobody an hear me
May 16, 2014 | Cell Phones
Oce 3165 m6106 error
check inside ttf. The whole unit comes in two sections connected with the shaft in the middle. Remove it and take both units apart. Now, left hand unit is called ttf while the right is pre heat and convoyer. There is 3 heaters in ttf and another 3 inside convoyer. Also please check both belts.
Jan 22, 2014 | OCE Office Equipment & Supplies
Have nokia 1110i.I can hear the caller but caller cannot hear me.
I believe the problem is the your mic. You may find that when you look at the underside of the fone it may show you bits of corrosion.
The good news is that the fault is not that big and you can easily solve this by purchasing a CRC AUTO ELECTRONIC CLEANER at your nearest hardware store. Apply a little to the corroded area and test fone again after 3 minutes.
Keep me posted with your progress. If in doubt contact me.
Jun 05, 2009 | Nokia Cell Phones
Caller can't hear me and I can't hear them
If your phone is newer, then take it to the Aple store to exchange. If they did not replace it for you, then you need a professional to replace the MIC.
Thank you
Apr 02, 2009 | Apple iPhone Smartphone
Vtech cordless phone appears to be mute
Try the "hard reboot". /1/ Unplug power from base station. /2/ Disconnect battery in each handset. /3/ Wait a few minutes. /4/ Reconnect battery. /5/ Re-plug-in power to base station. /6/ Place handset in base station, and wait a few minutes for it to recover.
You may have to reset time/date and/or the handset ##.
Aug 24, 2008 | Vtech 9009111 Cordless Phone
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
