Question about Garden
61in. scag cv22s kolar starts and runs when switch for blades is turned on blades turn but power rpm,s drop about 70%
Steve do you have any other ideas on this?
  • Garden Master
  • 7,943 Answers
Ill suggest you have some seized bearings on the mower deck itself
Posted on Jul 17, 2017
Testimonial: "thanks for your input but there are no seized bearing . any other suggestion would be great."
  • 1 more comment
  •  steve
    steve Jul 17, 2017
    does it have an electric clutch between the engine and the belt drive? i have seen other machines that do and thats why im wondering. something isnt right there for sure. what it is is the challenge. i wish i could help more.
  • terry albers
    terry albers Jul 20, 2017
    steve it dose have a elec. clutch and a pto switch that engages the blades any ideas?
  •  steve
    steve Jul 20, 2017
    im not sure how to test the clutch but maybe it has a bad bearing in it??
  • 22 Answers
SOURCE: bosh 4000 table saw , using dado blades.
no good solution for that problem. dado blades vibrate and cause the knob to turn. possibly a clamp on the knob to keep it in place.
tom
Posted on Dec 13, 2008
  • 6982 Answers
SOURCE: my rpm's drop below 1 when i get up to 70 and the
Check fuel pressure, change filter if delivery is low, change pump if pressure is not right after filter change. There could be more problems but that is where to look first.
Posted on Jun 26, 2009
nate6556
  • 103 Answers
SOURCE: Dash board, RPM, AC, Power window do not work and car is running
i would try a radiator, when it does start, take the positive battery cable off the battery, if the car dies, its your alternator\
Posted on Jul 25, 2009
  • 143 Answers
SOURCE: mower will run fine until i engage the mower blades
sounds like a governor arm is broken or missing . look for a small rod that should be attached to the carb under the throttle linkage. If missing altogether you may only find small arm with a hole in it where it should be, If unsure, consult mower shop.
Posted on Sep 20, 2009
  • 143 Answers
SOURCE: blade will not turn
motor will hum but no blade turn if bottom seal worn and material leaks into shaft. Rekove drive head and try turning shaft if nio go dissasemble entire unit ,clean and service, replace seals
I ran out of gas while mowing now my blades won't engage, what's my problem?
Sounds like you have 2 separate problems.
Once you get more gas and get the engine running you will have solved the first one.
If the blades will still not engage, shut the engine OFF and check the drive belts, idlers, and spring on the tension idler.
Sep 19, 2015 | Scag STT61V-35BVAC-SS Gas, Hydro Turf...
Why will the cutter blades on scag SW36A not engage?
I am thinking this is a 12 volt PTO system that does not have a battery... this is where you need to check the wiring, especially the big white plug on the right side of the mower... It might also be a mechanical engagement system, if this is the case, suspect the belt popped of or is way out of adjustment
Sep 12, 2014 | Garden
Engine cuts out wen blades turned on
You either have a faulty PTO switch or a faulty seat switch
The saftey shut down circut usually has four switches that have to be made to start motor and engage blades
both steer levers have one each
seat has one
lever conected for parking brake has one
scag might use plug in relays which could be bad too
Aug 09, 2014 | Scag SVR61V-801FX V-Ride Hydro Stand-on...
Scag mower
If equipt, check the low oil switch circuit. Might be a failing switch.
Sep 24, 2013 | Scag STT61V-791DFI-SS Gas Turf Tiger...
Blades will not engage but will remain running
It is most likely the switch. I had the same problem and that fixed. I found the switch on Amazon for less than $20. Stens 430-798 PTO Switch Replaces Scag 483957
Apr 05, 2013 | Scag SFZ52-26BS Freedom Z Zero Turn Rider
Jul 25, 2009 | 1997 Nissan.5 Altima
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
