Question about Zebra Z4Mplus Label Printer
Print Width Issue
My Customer Uses Zebra Printer in all geographies... We had orderd a Zebra Printer Z4mPlus, when we send a print from SAP Module the Print covers only 60% of the label and not 100%. All the Zebra Printers in other locations show Print Width as 104 0/8 MM. The one we use at this site shows 104 0/12MM, it seems that other location use 200 DPI as per Zebra Engineer and we are using 300 DPI Print head, any way to change the configuration to use 200 DPI and get 100% print on the Label. Again the Print out is complete only that it is smaller and covers only 60% of Label compared ot other location which is big and covers full 100%. We understand with 200 DPI the resolution will be small but we need complete width label print.
  • Anonymous Mar 12, 2014
    change resolution to 200 dpi
  • Anonymous Mar 14, 2014
    We have a ZP500 plus zebra printer. Frequently it will not print an area on the bottom and center of the label, therefore the bar code and tracking number is not complete. We have cleaned the head. Ideas?
  • 53 Answers
The issue you are having is DPI related, when data is sent to the printer and rendered it is dot for dot, so a Z4M 203dpi printer has about 800dots on the printhead where your printer has about 1200dots on the printhead. so when your software prints to dot800 thinking it is the edge of the label it is infact at 60%. there sould be an option in the software to configure around this. if not the is an option in the printer to convert DPI setting ie 150>300 or 100>200 and so on. but i don't thing you can make a 300dpi print as 203dpi
best of luck
Posted on Dec 07, 2007
Once you swap the printhead you will have to flip the pulley on the drive motor, or the label length will be off.
Posted on Jun 24, 2008
Thanks for the response, I did try the formatting option from 150>300 or 100>200, it does expand the print or you can say zoom the print, but the print appearing on the label is way tooo big... it drops half the content out of the label... none of the format provided helps in getting the print at 100%. The only option would be to make changes in SAP module to reduce the print size but that would mean changes geographically for all printers. changes in SAP module print settings for just one printer running on 300 DPI would have have all 200 DPI prints on 80%.
Do you suggest we go ahead and replace just the Print Head from 300 DPI to 200DPI, as it is I have tried all combination but the result solution comes to printer head replacement.
Posted on Dec 10, 2007
PRINTS ON ONLY HALF OF THE LABEL
If the printing clearly stops, then the maximum width setting of the printer is not set to the full 4 inches (104mm) of the printhead. Go into the setup mode on the printer and look for the setting called PRINT WIDTH and make sure it's set to 104mm or close to that. If printing is only half way across the label, it's because the width is set to something less than 104mm.
if the print fades away off the label, that is due to an imbalance in the pressure across the printhead.
Hope that helps !
Feb 18, 2010 | Zebra Z4Mplus Label Printer
My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Jan 13, 2010 | Zebra Z4Mplus Label Printer
Zebra Z4m+ won't print from Bartender 9.01
BarTender uses its own drivers for each model of printer you must install the correct driver, because there are differences in some commands a printer to another.
Mar 09, 2009 | Zebra Z4MPlus Printer
Can't save the printer darkness in the printer
go to printer driver properties.. 1.click printing preferences set it to USE PRINTER CONFIGURATION 2.go to advance click Printing Defaults set it to USE PRINTER CONFIGURATION
you must set this two configuration note: fresh installed driver defaulth to software control
Oct 14, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Aug 01, 2008 | Zebra Z4Mplus Label Printer
Zebra z4mplus
iN THE DRIVER CHECK THE head TEMPERATURE ISSUE. Most certainly you do not heat enough to do the transfer.
Else your ribbon is not mounted correctly. Zebra has an out inking transfer film
May 21, 2008 | Zebra Z4Mplus Label Printer
Z4Mplus doesn't save configuration
I had the same issue.
I'm using the seagull scientific drivers.
It turns out that the printer did not react well to changes made to it through the software.
I deleted the printer and added it again.
I made all my changes immediately through the software (creating a custom label size of 4in x 1in and portrait 180)
My print width setting on the printer is still 099 6/8 but everything prints fine.
Apr 17, 2008 | Zebra Z4Mplus Label Printer
Label Printing
Forward length matters in Label size detection. Width is just secondary. Length should be same for both. Else no, you have to had separate roll for each label size.
If the labels are same in length then there might be achance using Label Software that supports your printer.
Jan 24, 2008 | Zebra Z4Mplus Label Printer
When printing more then 10 labels from Acrobat some of them are missing
Hello!
Dear
I need ur assistance about this types of Model TLP-2844,LP-2844,S4M,S-600,105SL,110xiii,140xiiiPlus,Z4M,Z4MPlus,How can I Install a Printer With Label and Ribbon?Can U help me regarding this problem?I am waiting for ur assistance.If possible please send me a video file about how to Install a Zebra Printer with label and Ribbon.
Dec 13, 2007 | Zebra Z4Mplus Label Printer
Zebra z4mplus printer resets to thermal transfer
Please go to the inhouse program & click printer properties and
change the printer setup to direct thermal and that's it.
Joe
Dec 12, 2007 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
1,900 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
