Question about Refrigerators
Ice forming inside the refrigerator on the back wall on the left side
    Scholar:
  • 117 Answers
You have a defrost problem and will have to remove the back cover to access the condensor to fix it. You should see a condensor blocked with ice and also blocking heat transfer to freezer. Thaw out with hair dryer then you will need to cut wires to defrost thermostat (round thingy wired before defrost heater) Bypass the thermostat and manually set defrost timer into defrost mode by turning clockwise with screwdriver until you hear a loud click.. if the heater comes on then you have a bad defrost thermostat. If the heater does not come on then you need to check the heater with a ohm meter for continuity. hope this helps
Posted on Jul 27, 2009
Ice build up
Hi
is it brand new?
Jul 15, 2008 | Sub-Zero 632 / S
I bought a maytag side by side in 2002; model # MSD2454GRQ, SN 18157432AL, REV # 18. Ice is forming at the bottom of the maytag freezer department. Overnight ice will form at about 1/8 inch and left has...
Defrost problem: 3 components. Defrost Heater. Timer (circuit board or motorized) & Thermostat.
Remove cover on the inside back wall (usually 6 screws). Note frost pattern. (bottom of evaporator coil)
Put refrigerator into defrost cycle and note the defrost heater come on, or not. (careful heater can glow red hot)... Unplug Frige and test defrost components. Replace bad component... Refrigerator should defrost every 8 hours. when the cycle slows or quits the freezer will freeze over the evaporator coil and no air flow = no cold air...
Nov 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
Our kennmore side by side referigerator bought two years ago seems to have lot of ice in the freezer compartment. there is ice formed over the vents in the referigerator side and things (milk) is getting...
is the ice on the back wall or was the door left open?also send the model number,you'll find it in the fridge side on the right hand wall up near the ceiling,it will start with like 106. or similar
Sep 04, 2010 | Kenmore Refrigerators
Ice forming in the bottom of the freezer
Unclogh the drain hole inside the freezer in the bottom of the bakc wall pouring hot water until the ice melted and keep pouring until goes through.Repet this every 3 or 4 months to keep it clear.
Jul 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Sub-Zero 690 Refrig Side Ice Forming on Back Wall
replacing leaking evaporator on Sub Zero Video
Jun 09, 2009 | Sub-Zero 642
Ice forming in refrigerator
Sounds like the defrost system is not functioning properly. There are a lot of possibilities -- probably ought to call service unless you have significant experience with appliance repair.
May 08, 2009 | Refrigerators
Sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Ice is forming inside the refrigerator
You have a freon leak in you evapator. Call an authorized Sub Zero service company it will be coverd by you sealed system warranty..
Water always inside refrigerator sometimes ice forms
Sounds like you might have a condensation problem. Is the fan in your freezer working? If not it's not circulating the cold air. If it is you might have frost on the lower rear wall of your freezer meaning its not defrosting like it should and restricting your air flow. Last but not least you have a damper door in the upper left corner of your fridge that allows the cold air from your freezer into the fridge to cool it, that might not be opening up. Any one of these things would cause your water problem and a warm fridge section
Dec 05, 2007 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrigerators Logo
826 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
