Question about byD sign d:5032 50 in. HD-Ready Plasma Television
I broke the HMI input on my by d:sign monitor and need to have a new connector soldered to the board. Do you have any recomendations as to who can do that for me? Thanks. My email is n.siegenthaler@att.net
    Novelist:
  • 154 Answers
Look for a TV repair shop in the vicinity of where you live.
They should be able to get the parts for your specific tv and perform the repair.
Posted on Jul 27, 2009
Dvc860e--need a new remote control
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
https://www.abctay.com/tv-power-supply-c-2
Oct 16, 2017 | Televison & Video
A light horizontal line has appeared on my Samsung UN55C6500 TV. Is there a fix for this?
Horizontal lines on LCD TV,
not usually repairable
plasma may have a corroded or dirty connection on ribbon cable left side of TV looking from the rear
Apr 25, 2017 | Samsung Televison & Video
Samsung led tv ua40F6400 power board
If you wish to buy a new power board, contact the authorized service centre for Samsung.
Jun 27, 2013 | Televison & Video
Riccar 1700 melted connector to circuit board...
It might be an easy fix but should be done by a qualified Riccar dealer.
Jun 03, 2013 | Riccar Vacuums
My dell monitor turns yellow after sometime... What can I do for it? What are the possible solutions.?
Under options for the monitor try degauss. This will de magnetize the monitor which may help.
Don't try to fix anything on the inside because old CRT monitors have dangerous capacitors
that can cause an electrical shock even when unplugged. Personally I would recomend getting
a new flatscreen. In the US they are pretty cheap even for a large screen, and burn much less electricity and look much better. If looking for a new monitor check online usually much cheaper
than big box stores. Newer models also have better refresh rates than the 1st ones that came out
so if your a gamer the performance of most newer flatscreens is pretty good.
May 16, 2011 | Dell UltraScan 1600HS D1626HT 21" CRT...
My coaxial connector broke off. i have a new F connector now but i dont see where to solder it on to. can you help me find where i should solder on the f connector?
The connector needs to be soldered in two ways. The center connector needs to be soldered to the same point as the original. This may have broke off close to the small circuit board inside the tuner and you hopefully can see the broken piece sticking out. The tuner should ideally be removed to accomplish this. The tuner usually has two shields that snap in place that can be removed. You may be able to solder a short piece of wire to the remainder of the original connector. The outside of the f connector also needs to be soldered to the tuner shielding itself as a ground connection and you will need a soldering gun or higher wattage iron for this step. Use a lower wattage soldering pencil for the signal connection to the tuner board.
Nov 18, 2009 | Televison & Video
My VGA plug is missing on my monitor
If the cable does not disconnect from the monitor, then go ahead and buy a new connector http://www.startech.com/item/C15HPSM-High-Density-DB15-Male-VGA-Solder-Connector.aspx
I recomend this over buying a generic VGA cable and splicing wires, for better connectivity and less 'noise'.
Aug 06, 2009 | Neovo F-417 17" LCD Monitor
Cable input jack bronken off
Actually I just repaired one of these "similar" units. If you remove the backing of the tv, unpluged of course, Theres a panel facing you if you are looking at the right side of the TV. This panel pops off easily with a light prying motion all around. You'll see where the connector broke off and can solder it back together with a small pin type tip. Solder the center pin to the center probe first,hold in place with needle nose pliers. 2 people are better than one at this. Then lay down agood bead of solder around the perimeter of the connector. Clean up any solder that may have dropped and put it back together, you'll be ready to go in about one hours time. Let me know how it goes!!!
Jul 25, 2009 | Orion STV2763 27" TV
The HDMI connector broke loose from its mounting inside the tv.
hi there, you can just re solder the points onto the board once more without buying a completely new board. just remove the board and solder the contact point back on the board itself.that should fix it up for ya. thx for using fixya:)
Feb 08, 2009 | Samsung LNR269D 26 in. LCD Television
Main cable connector broke off back of TV
Maybe so. Sometimes the connector is fed by an RCA connector which just plugs in inside the TV and sometimes it needs a little solder work. Sometimes you have to solder on the circuit board and if it's a multi-layer board you want an expert to do it but from the manual it doesn't look like that is the case with your TV.
I'm pretty sure Radio Shack stocks such connectors with maybe a little hardware to get the fit right.
Dec 17, 2008 | Televison & Video
byD sign d:5032 50 in. HD-Ready Plasma Television Logo
63 people viewed this question
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
