Question about Toshiba Televison & Video
Toshiba model CF35D50 TV has no sound
No its not the swith on back that says int or ext speakers?  I get no sound even when I hook speakers up to the ext speaker port, and no sound when I hook a stereo up to the RCA outputs.  I am looking for a solid tip to what I can look for inside TV, or a repair manual free. Toshiba model # CF35D50
Chassis # 9411 built in sept 1994
  • 2 more comments
  • bjingles Jul 27, 2009
    It has one main board with a section outlined that says Audio.  But I dont know how to test it with out a service manual.  anytips
    I thought this site had service manuals? yes or no
    Ya I have an Tektronix O-Scope and Fluke meter but without a schmatic or service manual I am kinda going at it blind.  I did a real good visual check and found one looked like a mosfet that was cold soldier down. Fixed that and still same thing.  I was just hoping for a manual or a tip on what the pin out was on the main amp on the board so I could test in put and output signals.  I would really like to get this fixed and I am in no hurry.  DO you know of any good website that have what I am looking for?
    Thanks
  • 3,037 Answers
The audio board is most likely bad if you have no audio out of any of the outputs. This board can be found by following the wiring from the speakers to it. Since this is an older tv, it in my opinion may not be worth fixing as other problems will probably arise and finding a new board will be hard, so hopefully you will find a bad capacitor (look for one with a swelling top), or another component that doesn't check out. I hope this helps. Let me know how this turns out.
Benjamin
Posted on Jul 27, 2009
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Jul 27, 2009
    No this site doesn't have service manuals for all tvs, we may have manuals for some products, but most of them will not, it depends on what users upload onto the site. Service manuals are quite expensive usually too and rare to come by online.
  • Benjamin Patri
    Sorry I missed your other comment. Any resistors will test infinite resistance if bad, but without an oscilloscope, it is hard to test most of the board, generally shops just replace boards since it is easier unless something stands out like a broken or burnt connection or component.
  • Benjamin Patri
    As this is an older tv, I don't have a service manual and the sites I checked don't have it either, your best bet would be seeing if a shop would have one to sell or if Toshiba might have one still for this tv. Sorry I can't be more help on this
No audio. good video
Not familiar with this make of TV, but some TV's require you make a change to the audio menu from int. to ext. speakers. Do the internal speakers work and if they do, besides the menu change are you useing an external amp with your surround system?
Aug 23, 2012 | Polaroid TLA-01911C TV
How do we hook up speakers to our lg 42 inch tv, at the store we didnt realize it only had speakers in the back of the tv which hinders the sound?
depending on your model look in the back or side for (ext speakers) audio jacks out...this is where plug your ext speakers...if you are plan on using a 5 to 1 stereo receiver the speakers will be plug into the rec...
Jun 06, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv has no sound
check your menu and make sure your speakers are on for the tv. also make sure your connections to the tv- have audio going to the tv. on certain tv's they have an internal-external manual swith on the back of the set that could be in ext instead of int-if so switch it to int. beyond that you need to call for service.
Apr 21, 2010 | Mitsubishi CS-40505 TV
Samsung HCR4755W Picture is perfect but there is no sound
Hello MMiller3355:
First make sure u check ur audio menu in tv settings, Make sure the internal speaker are in the on mode, If you are using a seperate Audio amplifier for sound or a cable box make sure the settings are right and you are not in passthru mode, Also you might want to look in the back of you set to see if it has an EXT or INT speaker swith, which accidently got pushed in the EXT mode. If so switch to INT mode.. Hopes this helps you. If you find all settings are right then I would look to servicing the Audion Output Board and or the Audio output IC..
Aug 01, 2009 | Samsung HC-R4755W 47" HDTV
Disconnected RCA plugs from 52'' RCA and now no sound even...
ont back of the set there are a set of jacks you can hook ext speakers to make sure that switch is turned to int speakers
Nov 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" Projection HDTV Ready Model "D52W26 (No Sound)
Maybe the sound is muted. Try pressing the volume up button to restore sound.
• If using S-Video or Y, PB, PR, remember to also connect the component’s left and right audio output jacks to the TV’s L and R Audio
Input jacks.
• If you're using the TV's internal speakers, make sure the INT/EXT switch on the back of the TV is put on “INT”.
• The sound settings may not be set correctly.
Nov 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca has a picture but the sound has gone out - help!
Model number ?..... But look, select menu and see audio options ( speaker ext on ). Or see back cover tv bottom a little switch int-ext . I go for menu configuratios. Thank you
May 11, 2008 | Televison & Video
Toshiba model cf35d50 tv how and what type of speakers are require for external use the main tv speaker is blown
My Toshiba model number CF35D50 has lost the red in the picture. How do I fix this?
May 03, 2008 | Televison & Video
I have NO sound!
Check for two locations - on the back of the set itself, lower right hand side. A switch for the speakers (EXT -up-, INT -down-) should be in the down INT position for the TV's internal speakers. Also on the TV screen go to MENU> AUDIO> SPEAKERS> press enter to check the ON button. Of course the other option is a separate amp (using the rear Audio Output RCA jacks), or below that the LEFT/RIGHT external speaker connectors.
Oct 16, 2007 | Proscan PS38000 TV
Televison & Video Logo
74 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
