My tv won't come on. when i hit the power button, the blue power and two red lights flash (temp and lamp) flashes. after a while the lamp light remains on and the TV doesn't. Can you help.
    Scholar:
  • 70 Answers
Depending on make and model it could be a need to depress the circuit breaker reset located on the outside in the back of the set.
Or whats called a internal flashback or a capacitor that's not functioning.{ since you're getting power but no picture }
If the set doesn't illuminate / light up and there was no picture / color loss prior I doubt it's the tube or projection lamps assembly.
Posted on Jul 27, 2009
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Heard a loup pop when I turned the tv on; the timer/lamp/standby/temp lights on the power on button are now flashing; when I pushed the power button again the lamp light on the power button flashes and...
Color Wheel - Pull out the Lamp using a flash light look right into where Lamp was you should see the color wheel turn TV on watch to see if wheel is turning,From what you have said Problem will be the Color Wheel. Encompass Parts Distribution has them 1-800-638-3328
Sep 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Blue power light keeps flashing, but the tv won't turn on
Same thing just happened to mine. I think these replacement lamps (L2114A) are nearly impossible to find. They are no longer available through HP and I've ben unable to locate one through a reseller.
Oct 31, 2009 | HP Md5880n 58 in. HDTV
Tv will not power up blue power light flashing,red temp and red lamp lights flashing
The lamp is likely blown - it is loacated behind the front panel and can be pulled out to check - unplug set and do not touch front of lamp.
Oct 11, 2009 | Hitachi 50C10 LCD TV
Tv no picture 50vf820 red blue lights on?
Yes you should order a new lamp and replace it. if you are not real handy with tideous electronic tasks, consider buying the lamp in am enclosure for an additional $30
Apr 29, 2009 | Hitachi 50VF820 Projection TV
TV WILL NOT TURN OFF
Greeting inmiltown,
It sounds like your approaching the end of your lamp's life. Most projection televisions have internal lamp timers. These lamp timers usually give you time to buy a new bulb before it needs to be replaced.
I hope this helps.
Jon
Go Ahead. Use Us.
Apr 24, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
Electro Med Services...
