Question about SanDisk Sansa e250 MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
Okay, when I plug in my Sandisk Sansa e250R (2GB) two removable disks appear under "My Computer", the first one is "Sansa e250R (F:)" and the second one is "Removable Disk (G:)". I put the 4GB micro sd into my Sandisk Sansa e250R (2GB) yet 'disk G' shows no capacity in used or free. Could it be player not being able to read that capacity of GB because I have a SD adapter for the 4GB micro SD and I put it in my digital player and it works fine. Or should go to a firmware upgrade even if it cleans out all my music or is it too risky as to damaging my Sandisk Sansa e250R (2GB).
In additon to that problem there is no longer a music folder list under 'disk F:' So I can't see what music is on there even thought its on the actual Sandisk Sansa e250R (2GB) and also I would like to know how to delete some songs on my Rhapsody channels.
  • 3 more comments
  • Anonymous Dec 08, 2007
    how do you delete the rhapsody channels from a sansa e250r mp3 player using windows media player, i have no idea and need a step by step to do it.
  • user10 Feb 16, 2008
    My computer does not recognize my SanDisk Sansa e250 MP3 Player, /4G/ ,though it has additional 1G microSD, BESIDES it shows locked blue screen, and can not be unlocked!
  • Anonymous May 11, 2008
    i can't see my music folder under removable disk
  • his_penguin Jun 08, 2008
    ok i have a similar problem except i can see the music on my sd card when i plug my mp3 into the computer, but when i unplug it and it refreshes the database it says "refresh database failed" and then it doesnt show any of my music on the card. also my sansa has been freezing often lately. does that have anything to do with the card? I wanna use my card can u guys please help me???!!?
  • Anonymous Oct 17, 2008
    i have the same problem my mp3 sansa e250 2GB wont connect and also now its juts a blue screen running and dont want to stop and also the computer dont recognize it soo what i should do ........ PLEASE HELP..
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Posted on Oct 16, 2008
  • 175 Answers
Try to use other usb cable cuz' somtimes its the cable problem too low in transfering a file.
Posted on Nov 22, 2007
How to expand my memory and what type of memory card to buy
It will certainly take a 2GB microSD card.
This link on Sandisk forums tells how to check if you have a version 2 that will take a 4GB.
Where to buy one? My local supermarket has them, or you could check a camera store, or even office supplies. as well as the usual computer or electronics stores.
Feb 11, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
Can I attach an 8 GB Micro SD Card in the expansion slot of my Sansa e250? If not, what is the maximum storage size it supports?
The e250 uses microSD cards, not microSDHC cards. The maximum size of microSD cards is 2GB. Anything larger are microSDHC cards.
Mar 16, 2010 | SanDisk Sansa e250 MP3 Player
2gb Sansa Fuze won't recognize 2gb Micro SD
place the blank card into the SanDisk player
go to SETTINGS press "enter"
go to SYSTEM SETTINGS press "enter
go to FORMAT press "enter"
it will ask "are you sure you want to format this device"?
select YES
dowload songs to REMOVABLE DISK drive F, at least that is what my PC assigned it to. You will overload your MP3 PLAYER if you continue to download to the Sanza Drive.
Hope this helps.
Aug 27, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa c240 and a 4 GB Micro SD HC card.
Sansa C240 can only read SD cards that are NOT SDHC - that means it can only read up to a 2gb Micros SD card.
Jun 05, 2009 | SanDisk Sansa c240 MP3 Player
How do I use the SanDisk adaptor and the SanDisk 2GB microSD
The micro card (the smaller one) can be used alone in a port that accepts (microSD ports)such as those on a Sansa c240, c250, e250 etc.
If you have a regular SD slot (larger than microSD) then you plug the micro card in the adapter and plug the whole into a regular SD slot.
Plug the card in your computer and copy paste the files. Or plug the micro card in an MP3 player that accepts it and use you music transfert software.
You only have one card (the micro SD one), which you can use in two possible slots.
Hope it helps.
May 19, 2009 | SanDisk 2GB microSD Memory Card
E250r memory expansion
the bigest is 2 GB micro sd
Nov 06, 2008 | SanDisk Sansa e250 MP3 Player
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
Sep 20, 2008 | SanDisk Sansa e260 MP3 Player
Micro sd card
You can only see the card thru My Computer as a removable disk.
You can manually transfer the files thru My Computer by dragging & dropping then onto the card.
Best of Luck.
Oct 23, 2007 | SanDisk Sansa e260 MP3 Player
2GB Micro Disk has problem playing MP3 and WMA
The SD card is too big for this sorry player - 256MB card or less
Jun 11, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa e250 MP3 Player Logo
5,458 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
