IGO tv connected with dish sound come from tv but pictur not show only blue color show
    Habit-Forming:
  • 24 Answers
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Posted on Jul 17, 2017
SOURCE:
  • 1694 Answers
SOURCE: Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Posted on Oct 17, 2007
ChadL777
  • 69 Answers
SOURCE: Color of people's faces in movies played via DVD is now blue since connected to LCD TV
The reason the picture is blue on the DVD is because you have poor video cables running the feed, probably RCA yellow cable im guessing. Get some nice component cables for the DVD feed and it will fix you right up.
Posted on Dec 26, 2007
danromarris
  • 101 Answers
SOURCE: Tv has sound but no picture.
If it works on DVD but not on your Dish, and when you connected it to another house it had the same problem then it sounds like your input connection is bad on the TV. That is if I am understanding this right. From what I am reading your Dish network is not showing a picture but the audio is working fine. The DVD player works fine on the TV though. Then you took the TV and hooked it to another dish system and it was the same problem. That sounds to me like you TV is having a problem, either that or the cables for your Dish network are bad. Try switching to a different input, like the one the DVD player is on and seeing if it works there. If not, then the cables are bad and you just need to replace the cables. If it does work though where the DVD was working before then your TV input is bad on that port you were hooked to before.
Let me know if you have any other questions and if this was helpful. If you need some more clarification let me know, I hope this is helpful. Good luck and have a good weekend. Get it fixed before the Super Bowl.
Posted on Jan 25, 2009
SOURCE: SONY TV MODEL # KP-65WV700 SER.# 9002706
Try to Google the new part number. Also, the old part number can be replaced. Google it also and the repair center, Video Display Corp., comes up...with pricing. I would like the new part numbers for the green and red tubes also.
Jim N.
Posted on Apr 09, 2009
  • 267 Answers
SOURCE: Tv blue light shows That TV is on But no picture
YOU PROBABLY HAVE A PROBLEM WITH THE POWER SUPPLY BOARD. DEFECTIVE CAPACITORS.
Posted on Jul 27, 2009
My tv doesn't show picture and there is no sound it only shows blue screen and the remote don't want to operate.what can I do? Panasonic
Most likely an analogue antenna or satellite dish connection, and or set-up problem! Don't you get a "NO Signal" warning? Check physically your antenna or dish, and connection cables, to ensure that all are correctly connected and not detached or loose. Check your TV menu set-up - make sure you have selected TV from the other possible options such as video, HDMI, USB etc. If that is all OK then call your TV specialist to correctly align your aerial or dish. The remote is likely a separate problem. Been dropped or something? Buy a new universal remote.
Aug 11, 2014 | Televison & Video
My igo 14'' tv no sound no picture all switches
Check the Logic board and switch modulator controller they are faulty
Apr 14, 2013 | Televison & Video
NO VOLUME AT ALL - GREAT PICTURE We have Dish
You will want to start by unplugging the receiver for ten aseconds. If this doesn't resolve the issue check the cable from the receiver to the TV if it is a single cable with a flat end then just ensure both ends are firmly connected. If you are using component cables with 5 colored ends (red, green, blue, white, and red) make sure the red and white audio cables are connected on both ends. If this fails to resolve the issue reply to this and I will get back to you!
Daniel Busa
DISH Network
Customer Service
Jun 24, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Trying to hook up a dvd and wii with direct tv and can"t get sound out of wii! HELP Can you show me where to plug cords in?
Your TV has two sets of AV inputs. One on the side and one at the back. The Wii has a 3RCA cable ( Yellow / Red & White ) . Connect these jacks to the corresponding color sockets on the side input of your TV. Select that input on the TV and your Wii sound and picture should come on.
For the DVD player you have to get a 5 RCA component cable. This cable will have 5 colored jacks, connect the White & Red to the Audio in of the TV and then connect the Red/Blue/Green jacks to the component video input of the TV.Do the same at the DVD's end also. Setect that source on the TV and you should hear the DVD sound and picture.bobhifi_31.jpg
Apr 03, 2011 | RCA L32HD41 LCD TV
No picture, but sound
does it work if you connect dish??
Mar 30, 2008 | JVC LT-26WX84 26 in. LCD HDTV
Blue and red color are off, picture is not clear
convergence amp ic bad
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | Sony KP-43HT20 43" Rear Projection...
Sound but No Picture
Connect your outdoor antenna directly to your antenna in, in your TV see if it works and do the same with your cable input if it works then the A/B box is at fault.
Oct 28, 2007 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
