Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer defrosting arbitrarily
Freezer defrosting arbitraril. It will just start to defrost everything in the freezer. Then when i remove all the food , it will work again, and then it repeats this after a short time. It seems to have this problem when the ice cube tray gets full or hasn't been used for a while . This is a GE side by Side lsss25xg
  • GE Master
  • 4,655 Answers
Because your refrigerator is doing these erratic things I need you or someone to check a few things. I need you to pull the refrigerator away from the wall and remove the panel that covers the compressor. I want you to feel the compressor and see if it's too hot to the touch. I need you to make sure the fan is running all the time at the compressor below and inside.Make sure the area below is also free of dust.These test will help me to determine what is going on with your refrigerator. And then get back with me and tell me what you find. Thanks, Sea Breeze
Posted on Jul 27, 2009
  • John Tripp
    John Tripp Jul 27, 2009
    Your refrigerator has a defrost timer located in the fresh food section behind the control panel. I want you to locate a hole most times covered by a plastic plug. Remove the plug and slowly turn the timer with a flathead screwdriver until you hear the compressor stop. This puts the refrigerator into defrost cycle. Leave like this for about 25 minutes and the refrigerator should restart on its own. During this time open the freezer door and listen for crackling or sizzling. This is the defrost melting the ice and dripping onto the defrost element. Below is a photo of the timer location. And a link to a replacement defrost timer.
    Here is a link to the defrost timer=>
    215846602 Defrost Timer
    If it's not the timer it will be the defrost heater and defrost thermostat. I want you try the timer first and get back with me, Thanks, Sea Breeze
  • John Tripp
    Here is a link to mu Web Site=> http://servicepartstec.blogspot.com/
MY MAGIC CHEF IWORKS FINE 2 TO 3 WEEKS A TIME ,AFTER 3 WEEKS IT STOPS COOLING - I REMOVE EVERYTHING OUT FRIDGE AND UNPLUG IT FOR A DAY ,A DAY LATER I PLUG BACK AND IT OPERATES FINE FOR ABOUT 3 WEEKS AND I...
Hi and welcome to FixYa, I am Kelly
Without your model number here is what most likely has happened:
The automatic defrosting system is not working due to a component failure.
The components of the automatic defrost system are:
1. Defrost control
2. Defrost heater
3. Defrost thermostat.
4. Wiring to inter-connect 1 - 3 above.
What your currently doing is a manual defrost cycle every 3 weeks because ice blocks the air-flow across the evaporator in the freezer compartment so everything starts warming up in the fresh food section first and finally the freezer as the ice block gets larger.
FYI you can unplug it... remove the contents from the freezer...use an external directed into the freezer compartment for just over 2 hours to do the same process your doing in 24 hours. Until the automatic defrost system is repaired you should do a manual defrost at least every 4 days.
Most units are on an automatic defrost cycle of 6 - 8 hours (usually) all the way up to 10.35 hours per cycle. Yours just is not working at all.
Thanks for choosing FixYa,
Kelly
Kelly
Aug 15, 2011 | Refrigerators
Frezzer stuck in defrost cycle
You have a bad thermostat . The piece the refrig temp knob is on ( not the freezer knob , it works off an adjusting rod ) .
Nov 12, 2009 | Kenmore Refrigerators
Area around freezer opening on a PDS20S GE
This is uaually caused by the condenser fan next to the compressor not running. Remove the cardboard backing to see it, give it a spin if it's not running. Even if it starts running with a spin you'll need to replace it.
Or If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too. check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | GE PDS20MBS Bottom Freezer Refrigerator
Freezer has slight frost built up. Fridge is only slightly cold - set on 7. It is 5 years old. What might the problem be?
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up heavily because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 29, 2009 | Refrigerators
Freezer working fridge not
There are screws around the edge to remove it. It's probably iced up due to defrost system failure. How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 25, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Ice under the cover
You can use a hairdryer to speed it up but you need to fix the defrost sytem.
Aug 20, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer is working good fridge is not very cold .make whirlpool
OR
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 16, 2009 | Refrigerators
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
140 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
