Question about ATI Asus P4R800-V Deluxe Radeon FSB800 Prescott Ready Motherboard (MOTAS30)
Question to motherboard
How can i find the cmos? a side from motherboard.. thanks
Press f1 or f2 after the single beep sound come .it will go to cmos settings .
if you have any problem i that contact me :
Posted on Nov 22, 2007
How can i remove the battery
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
ASUS motherboards, manufactured for both Intel and AMD processors, are a popular choice for custom-built computers.
The motherboard's battery is a flat, round 3-volt lithium battery.
This battery, which is installed in a special motherboard socket, powers up CMOS (complementary metal--oxide--semiconductor).
CMOS is an integrated motherboard chip that stores current BIOS (Basic Input/Output System) settings, such as system date and time.
A CMOS battery may last for many years, but eventually dies.
So you need to replace it.
Purchase a new CMOS battery available from many retailers (see Resources section). ASUS motherboards typically use a lithium CR2032 battery.
Turn off the computer.
Remove the computer case side panel.
Lay the computer on its side.
Find the CMOS battery that is situated in the socket approximately in the center of the motherboard.
Touch an unpainted metal part of the computer case or another metal surface to discharge static electricity.
Lift the CMOS battery out of its socket, using your fingers, and set it aside.
Insert the new lithium battery gently into the socket. Make sure that the battery's positive pole, marked with a plus sign (+), faces up.
Move the computer into the upright position and close the side panel of the computer case.
Press the "Power" button to turn the computer on.
Hope this helps.
Nov 25, 2012 | ASUS P4S800 Motherboard
Hi... i have gigabyte ga-945gcm-s2c and i dont know where is the jumper to bios clearing CMOS... please help me to fix this problem... thanks before....
You can get the manual here:
But if you look to the right of the CMOS battery, you will see two pins, to reset the cmos, simply cap the pins with a jumper for 10 secs, or touch them with a screwdriver (mains power OFF of course)
Apr 19, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
Where is the cmos battery on easynote r0901?
Hi moose2990, this is a [Picture Diagram].
CMOS Battery on the "Motherboard!"
replace-packard-bell-486-battery-200x200.jpg "This is a "Picture of a CMOS Battery on a {Packard Bell} Motherboard."
"This is a picture of a [CMOS Battery], on 'most' Motherboards!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 09, 2011 | Packard Bell (181368) Motherboard
What is the correct battery for the BIOS memory for a Gateway model 4025GZ notebook ?
When your Gateway computer is switched off, it still keeps track of various system information such as the date and time, thanks to a small battery that never powers off. The size and thickness of a dime, the CMOS battery can run out and need to be replaced. You can swap out a dead CMOS battery with a new one by removing the Gateway computer's side access panel.
Difficulty: Moderate
Instructions Things You'll Need:
  • Phillips-head screwdriver
  • CMOS battery replacement
  1. 1
    Shut down the computer. Remove the power cable from the back of the computer case. Disconnect the cables for the monitor, mouse, keyboard, and printer.
  2. 2
    Set the computer case over on its side. Use the Phillips-head screwdriver to remove the two case screws at the far left end of the case.
  3. 3
    Slide the side access panel to the left and remove it from the computer case. Find the CMOS battery port, which will be located to the lower left of the processor in most Gateway computer models.
  4. 4
    Lift up the plastic clip holding the CMOS battery in place. Slide a fingernail under one side of the battery and lift it off the motherboard port.
  5. 5
    Check the orientation of the new battery and compare it to the CMOS motherboard port. Push the new battery into place in the same direction that the old battery was facing. Push down the plastic clip.
  6. 6
    Set the side access panel back onto the Gateway computer case and reattach the case screws. Plug in the Gateway computer and power it on.
Jan 01, 2011 | Gateway 4025GZ Notebook
Cmos error-defaults loaded failed!
Please follow the following step to correct this error:
1. Change the CMOS battery,
2. Reset the CMOS Settings by using the CMOS Jumpers on the Motherboard.
3. Start the PC, enter BIOS setup.
4. Load the default settings
5. Save, Exit and restart the PC
Nov 20, 2009 | Intel Motherboard
CMOS Battery location on samsung vm8000
cmos battery is underneath. Take off fan cover. remove fan screws x 4. Then lift black cloth on right hand side. You will see the offender. Lift the battery from the left hand side gently with a small flat head screw driver....
Dec 10, 2008 | Samsung Computers & Internet
845gvsr support
single-sided or double-sided DIMMs (ddr333/266/200 or pc2600 or pc2100 or pc1600) up to 2GB check ur RAM FSB (it mustbe 333mhz or 266mhz or 200mhz).
it its within this speed then cleare cmos by removeing cmos battery then install ram and start ur pc. if problem not solve then try with other good known ram (ddr333 or ddr 266 or ddr200). if problem solve then ur ram module r faulty.
(plese give me feedback)
Jul 01, 2008 | Intel D845GVSR Motherboard
Gateway 450rog cmos battery
The CMOS battery is located on the motherboard, just under the bottom left side of the keyboard, by the letter 'V". It looks like a clock battery, marked 3V (volts). The battery comes out of its "cage/connector" by gently lifting it with a small flat screwdriver. Replacement CMOS batteries are inexpensive and readily available at any computer shop. Hope that helps
Mar 15, 2008 | Gateway 450ROG Notebook
ATI Asus P4R800-V Deluxe Radeon FSB800 Prescott Ready Motherboard (MOTAS30) Logo
37 people viewed this question
Top ATI Computers & Internet Experts
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
