Question about Sport & Outdoor - Others
Our 1995 Pace Arrow Motor Home burns up alternators and cells in batteries. We have been told that since we tow a 2006 Jeep Wrangler, it could possibly need n Automatic Dinghy Battery Disconnect and also that possibly all the ground wires should be replaced. What's up??? Thanks, Linda
    President:
  • 1,776 Answers
The next time you have the motor home out and about, stop at an autoparts store and have them test the alternator output. There could be a faulty voltage regulator causing the problem or you could have a bad engine ground. Follow the negative battery cable down to where it is grounded on the engine and make sure that it is clean and tight. Check the insulation on the cable for broken or melted insulation. Also check the condition of the wires that go to and from the alternator for any signs of damage or shorting out. Hope this helped and best wishes.
Posted on Jul 27, 2009
1995 jeep wrangler wont go in gear
Actually, in some cases, the transmission may have a problem shifting only sometimes, if your TPS, VSS, or any solenoid on the transmission is going bad. an intermittent problem could be the case; and sometimes, it's just a loose wire.
Apr 17, 2013 | 1995 Jeep Wrangler
Jeep Wrnagler will not start
Have the battery checked, sounds like you may have a bad cell
Nov 01, 2011 | 2003 Jeep Wrangler
Overheates in 4w. Now smoking and smells,mechanic unable to find. Initially thought it was fan motor but am told it checks out ok. Thermostat and hoses changed.
Hello, jilluptain and thank you for asking your question on Fixya!
Here is a simple process that will walk you through a few steps that will pinpoint the overheating problem on your
2006 Jeep Wrangler, without even using any tools. It has helped millions of people, and I am certain that it will help you, because I wrote it for people in your exact situation.
How to diagnose your overheating
2006 Jeep Wrangler
Get more great money saving tips and tricks about your vehicle from: twitter.com/acoates23234
Thanks for the vote, and good luck!
Jan 05, 2011 | 2006 Jeep Wrangler
My1995 Jeep Wrangler is hard to start when it is
CHECK BATTERY VOLTAGE.IT SHOULD BE 12.5 VOLTS.IF BATTERY OKAY.YOUR FUEL FILTER COULD BE STOPPED UP.OR YOU NEED NEW PLUGS + WIRES + CAP AND ROTOR.
Apr 18, 2010 | 1995 Jeep Wrangler
How to wire a jeep wrangler for towing behind a motorhome using a 7 way rv connector . the jeep has three wires, brown, green and yellow. green and yellow are turn signals, I am having problems with the...
I tow my 2005 Jeep Wrangler behind my motor home. I installed a Jeep trailer towing wiring kit to the rear lights. the bought a long trailer wiring kit and ran it from the front of the Jeep to the Jeep tralier wire plug. Pluged it in and pluged the other end into the motor home trailer light recptacle. I used only four wires plus ground. There is probably a way you could tap into the wiring harnes under the hood but not having a wiring diagram this is the best I could come up with and all lights do work. You can buy a test plug with led lights that plugs in both male and female, real handy for checking connections.
Jan 09, 2010 | 2004 Jeep Wrangler
The fan motor does not work in my 1995 Jeep Wrangler. The previous owner pressured washed under the hood, and the A/C blower has not worked since. What is the problem and how do i fix it?
The pressure may have knocked the electrical connector on the fan motor. Re-seat it.
I doubt that the motor is burned-out.
If that doesn't work,
Disconnect fan motor connector and turn ON engine & A/C compressor.
Check for 12 volts at the fan motor connector. If it's there, the motor is burned-out. If no voltage at the connector, then replace the "cooling fan" relay in the fuse box under the hood.
Sep 29, 2009 | 1995 Jeep Wrangler
Running light fuse for the tow plug on a 2006 jeep wrangler
does it have a fuse or is it connected directly to the wiring for the vehicle ??was it factory fitted or fitted afterwards
Jan 31, 2009 | 2006 Jeep Wrangler
Towing a 02' Jeep Wrangler
If you go to www.remcotowing.com it will give you the answer but I think you'll need a trailer.
Sep 13, 2008 | 2002 Jeep Wrangler
Sport & Outdoor - Others Logo
273 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
