Question about Intel D101GGC Motherboard
Sdhd scdsc
  • dbucyk May 11, 2010
    Can you tell me a few symptoms that you are having or concerns. I'm a A+, Network+, and Server+ certified technician.
  • tommya300
    tommya300 May 11, 2010
    Older SD readers will not read them
What does the mmc-SD card looks like?
Wikipedia has a picture of an MMC card at the MultiMediaCard page. Here's another one from CDW: Transcend flash memory card Does this help? SDHD is a gene; I think you may be referring to SDHC cards which are high capacity SD (secure digital) cards.
Nov 03, 2015 | ASUS Computers & Internet
Tip
SD camera cards
SD cards come in two varieties, ornery and HD. SDHD cards have a capacity greater than 2GB and cannot be read by some old card readers, either the separate kind which you plug in or those built in. If your card reader (or your PC) cannot read your new SDHD card you will have to buy a reader which can. They are usually pretty cheap.
on Dec 01, 2009 | Cameras
Everytime i put SDHC memory card in camera it shuts off... canon m1093 is
I've run into this problem with off brand or damaged SDHD memory cards. I just had another SD card go bad on me tonight. It happens. Sometimes they can become corrupted, and need to be low level formatted, and then sometimes formatted by the camera again before use.
Check out the SDHD card in something else, if you can. If it appears just fine there, then it may just be incompatible with the Kodak camera.
Try another SDHD card to see if it operates properly, which will most likely resolve the issue for you.
Feb 14, 2012 | Kodak EasyShare M1093 IS Digital Camera
TRIED TO UPDATE MY TOMTOM GO 710 BUT NOT ENOUGH MEMORY BOUGHT NEW CARD BUT TOM TOM WONT TAKE IT TRANSFERED DATA BACK ON TO OLD CARD BUT TOMTOM WONT TAKE THIS...SHOW TWO CROSSED HAND ON MEMORY CARD...
Just had the same problem..............
I discovered that you must only use an SD card and not an SDHD card.
I bought a bigger SD card (2Gig), installed it and copied the data I wanted without any probs. With the SDHD card I couldn't transfer anything and didn't get any help as to why...(there's a lot to be said for trial & error).
Hope this helps
Jun 09, 2011 | Tomtom GO 710 Car GPS Receiver
Our printer will not read a SDHD card,but it will read a minne duro with an adapter? Are we doing something wrong.
Your sdhd card is not authorized for printer you want to read, but you have to readable if it has unique readable card.
Be sure that it is unique or not or authorized by your printer.
Dec 03, 2010 | HP Photosmart C5180 All-In-One InkJet...
Can a pentax optio S5i support a 8GB memory card? Do I need to download a driver to support an 8GB memory card/
No the Pentax Optio S5i does not support an 8gb memory card.
8gb would be an SDHD card, the S5i came out before SDHD so it does not support them.
Standard Secure Digital Cards come up to 4GB in size so you could use one of these. The highest standard card I have is 2gb and that is fine in mine.
My S5i locks up if you put an SDHD card in.
The only firmware update that Pentax supply does not effect this, SDHD needs different hardware.
Jan 02, 2010 | Pentax Optio S5i Digital Camera
Does a SanDisk Cruzer 8gb USB 2.0 flash drive that requires a high power USB port work in a HPzv5240US laptop computer?
The new SDHD need to be seen by newer readers. A usb reads USB but the reader that is connected may not will not read the newer SDHD
Jul 27, 2009 | Cameras
Wich memory card suport the kp500??? micro SDHD....??????
micro SD is supportable to your moble..... any further query, you may reply...
Apr 24, 2009 | Cell Phones
IPAQ 6515 doesn't recognize new HP 8Gig SD card when inserted. I reset but nothing happened. Any idea what the problem might be.
I am sorry?
You want me to give you my solution for nothing and want to charge me $9.95 for it.
I could not find any posted solutions when I checked your site.
Dec 13, 2008 | HP iPAQ hw6515 Pocket PC
Intel D101GGC Motherboard Logo
132 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
