Question about Kenmore Microwave Ovens
I set the timer and instead I turned the microwave on an it ran for about 30 with nothing in it. It shut of and now everything works on it but what ever is used in them to make thing heat. Should I try to get it repaired or just get a new one?
    President:
  • 1,273 Answers
It depends on what you have and what you want. The following are my humble opinions, but you will be the one to decide for yourself....
If your microwave has some age on it, or if it has a history of problems, this should weigh more towards replacement. Also....If it is an inexpensive unit, replacement is probably the better choice, as parts tend to be higher than replacing the unit. Call your local appliance parts supply house and get the replacement cost for a magnetron tube for your model. Get some prices on models that meet your needs from local stores or the internet and are acceptable as a replacement. Also get a general cost of your unit when it was new. Here's how I do it: If the cost of repair is more than 50% of the cost of a new one, I'd replace it. My junk-it scale is 50%, but the percent drops if the unit has lots of age on it, or if I've had a history of previous repairs. The older it is, the more likely it is that it will break. It will also make a difference if you are making the repairs yourself, or hiring someone else. If you keep these things in mind, you will make the right choice.
Best regards, --W/D--
Posted on Jul 27, 2009
My GE Profile over range microwave spacemaker xl 1800 model jvm1870bf02 was working just perfect until my daughter decided to use the microwave as a timer and actual ran the microwave with nothing inside...
Magnetron is blown.
This high-energy microwave-transmitting device hides behind a small plate on side of oven.
The waveguide sticky-out part looks like a small tube.
Normally, water molecules absorb the energy, heating the food.
Without an absorbing 'load' inside the oven cavity, the high-frequency, high power energy bounces back into the magnetron and it destroys itself. (Magnetron Hari-Kiri).
In a nutshell, tech must renew magnetron.
Then iInstruct family members to never run it empty.
Oct 11, 2017 | GE JVM1850 1000 Watts Microwave Oven
I THOUGHT I SET THE TIMER-YET I HAD SET THE
Without food for the microwaves to be absorbed by, the magnetron (heating device) would have most likely overheated. There is a thermal overload switch (safety device) that acts like a fuse and turns everything off if overheating occurs like that. You would need someone that could take the microwave down, disassemble and check to see if the 'fuse' is bad or the magnetron is bad, they can both be checked with an ohmmeter. If you need to hire someone to do this, it may cost you more than the cost of a new unit if the magnetron is the item that has failed.
May 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
Microwave will not heat food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
wsw
Oct 09, 2008 | GE JVM1640 Microwave Oven
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
Just quit working...but not everything.
Hi , open the cover with philips screw driver , b sure unplug it first , If you have continuety tester check the fuse if open replace it , are available in electronics center brings that sample and insert it.
Apr 16, 2008 | Kenmore 62702 Microwave Oven
MICROWAVE LEFT ON...NOTHING INSIDE
You likely have a blown thermal cutout mounted above the magnetron, or possibly a blown fuse. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Jun 11, 2007 | GE JVM1860 Microwave Oven
Microwave Ovens Logo
47 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
