Question about Canon PowerShot A630 Digital Camera
Almost same problem
I m having the same problem since this morning . I can click images without using flash , But once i swith to Flash of Auto-Flash mode, i just cannot click them. The lenses are working just perfect, so is the quality of images that come out without the flash , I hope there is a convenient way to solve this
  • mihirsamel Jul 29, 2009
    thank you ... any idea how much it costs ?
  • 300 Answers
Hi!
It looks like the flash capacitor cannot be charged - could be a dead flash fuse. You should contact your local Canon service center.
Tom
Posted on Jul 28, 2009
  • Toms Safranovs
    Toms Safranovs Jul 29, 2009
    Don't know how much would it cost there, it would be about 20$ here.
    Tom
My sony w370's flash doesnt work...i mean the flash does work bt only smtyms.....wen it is kept for a few weeks without being used...........then it work and after clicking 15-20 images it again doesnt...
Be aware your camera is not a professional DSLR with external flash lights.
Most camera's will get warm or even hot when you take several pictures with the flash on in a short time. Most manuals do have a warning about using the flash. Sometimes the camera is only allowed to take a picture with the flash on, once a minute or even once in a couple of minutes. When the camera becomes hot, it will prevent itself against overheating, by not charging the flash again.
Still it can be possible something els is wrong with your camera, but try to shoot with the flash, with greater intervals and look if you can use the flash any longer. Also when the battery is drained, the flash won't charge. When shooting continuously, you will drain your battery much quicker.
Jan 19, 2014 | Sony Cybershot DSCW370 Digital Camera
Hi, the photos i take are getting blurred and the image is not at all clear no matter how shot the distance may be i click the image.the only new icon i see on the screen is vibration warning symbol along...
If you are shooting in Auto mode with flash, this should solve your problem. Make sure you are not dictating any of the settings, i.e. choosing a longer shutter speed, a very small aperture setting, or a very low ISO (sensitivity) setting.
Typically the vibration warning icon will appear when the camera is trying to use a long shutter speed without flash in order to get the right exposure for a darker scene. Your outdoor (bright light) photos are probably OK.
In dim light with a point and shoot camera, you can have your choice between 1. blurry (using a relatively slow shutter speed), 2. dark (using a shorter shutter speed but no flash), or 3. a good photo with flash (which uses a medium shutter speed and added light from the flash)
Mar 12, 2011 | Cameras
How do I disable the pop-up flash on Nikon D5000? Thanks
As long as jog dial is set to M or manual, the flash will not pop up automatically. Be reminded though because you have to set everything manually. If you want the auto settings without the flash, set the jog dial to the icon that looks like a lightning with stop/ no sign
Mar 02, 2011 | Nikon D5000 Body Only Digital Camera
Digital Camera HP Photosmart M517 Want to take a picture of my computer screen to send by email. Flash goes off every time and leaves a bright white light that obscures the screen. Can I disable the flash...
Press the flash button (just under the viewfinder) to cycle through the flash settings. Your choices are Auto Flash, Auto Flash with Red-eye Reduction, Flash On, Flash Off, and Night.
If you want to capture the screen image, you're better off using the computer operating system's screen-capture capability. This will give you the screen exactly as it is, without the distortions inherent in converting to an analog image and then converting it back to a digital image.
Mar 15, 2010 | HP Photosmart M517 Digital Camera
Flash blows out the image!!!
hi ,
it could be possible that the light sensor (the device under the red transparent plastic) in front of the flash is already failing. to test,set the camera mode to auto then cover the sensor with your hand and do some test shots, the images should be overexposed if the sensor is covered, then shoot some photos without covering the sensor, the images should be properly exposed , otherwise it might already be a light sensor failure .
Sep 30, 2008 | Nikon Speedlight SB-800 TTL Flash
No flash in "P" mode
In all of modes you can use "up" key to toggle between "always on", "auto"  and "off" mode for flash. (in some mode there is only auto and off.) also the flash light icon on top right of screen shows th status of flash. I hope this helps...
Aug 02, 2008 | Canon PowerShot A640 Digital Camera
Canon A75 Power shot
Try formatting the card once and then check it again, the problem is due to the reason that your camera's Auto focus is not working swith it to Auto mode disable Macro and then take Photos when the Green box appears on the LCD.
Joseph Manoj
+91 9352008418
I did not recieved any updates yet try the solution i suggested and your problem will be resolved.
Regards,
Manoj Joseph
+91 9352008418
Apr 29, 2008 | Canon PowerShot A75 Digital Camera
Nikon d 80 flash will not pop up while in auto mode
The flash up button is located on the left hand side of the camera right near the top.   You should use this button to pop up the flash. Prying it up could/has broken this button.
Also, depending on what setting you are using, the flash doesn't always pop up automatically.   Check to see what mode you are in, on the round dial on the left -- ie  Auto, Portrait, Manual, etc.   I can move sometimes without your knowledge, and this may be the problem.
Apr 15, 2008 | Nikon D80 Digital Camera with 18-135mm...
Shooting with External Flash
Without more information, it sounds like the flash may be set to a manual mode. Try setting the flash to an auto mode. The display should indicate something to the effect of "E-TTL" or maybe just "TTL". The reason your images are blurry, would be due to a slow shutter speed being used on the camera. If your flash is not set to trigger automatically, then the camera will use the slowest shutter speed to acheive the proper exposure of the image. My assumption would be that if you were to take two images back-to-back with the speedlight set to your current setting, one with the speedlight the other with the pop-up flash, the latter would not be blurry. Hope this helps.
Dec 07, 2007 | Canon Digital Rebel / EOS-300D Digital...
No image
No image in shooting mode on Canon S500. Flash operates and shutter clicks. Whats wrong?
Nov 12, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot A630 Digital Camera Logo
133 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
