Question about Refrigerators
Yesterday I came home and noticed my ice in the ice maker was melting. I pulled the back panel off and found the fan blade that cools the condensor was off so I put it back on. Today I get home and the frig/freezer is still not working. I hear the compressor trying to start, but after roughly 10 seconds it "clicks" and goes back on standby for a period of time and then trys to start again. Is it possibble it could be the capacitor or whatever it is called on the side of the compressor, or is it the compressor?
  • 3,037 Answers
This normally could be a bad start relay(most likely to fail and cheapest to replace) and over load for the compressor, dirty condenser coils need cleaning, condenser fan motor is not running or the compressor itself which may have overheated if the fan stopped cooling it. To check the compressor properly you should test it with an amp meter, each compressor is rated in running amps ( see model/serial tag or the sticker on the compressor )...if the compressor is drawing too much current, this may be why it is shutting off. Check the model tag for proper amp rating. Some relays will be easy to notice whether something is wrong with them, they may be burnt. Some of these relays can be removed and if you give them a little shake, and they rattle around inside, then the relay is likely bad. Compressors can also seize and click on and off or one of the electrical windings inside the compressor could have opened up. You can use a test cord to help check the compressor and this also will help with the amp test. If the compressor checks ok and you want to install a replacement start relay. You will first need to find out which winding is which. You will need an ohm meter to determine the windings. First check to see if you have windings in the compressor. Then check to see if they are grounded. If the compressor has windings and they are not grounded, you can find which winding is which. Check for grounded windings by reading from each terminal to a good ground on the cabinet. Read from the top terminal to the lower left terminal. Read from the top terminal to the lower right terminal. Read from the lower left terminal to the lower right terminal. Write down the resistance of each reading as you go. The highest reading you get will be the run and start winding of the compressor in series with each other. The other terminal left will be the common terminal. Read from the common terminal to each of the other terminals. The terminal with the lower resistance will be the run winding. The higher resistance the start winding. Using the original style relay is always preferred, but using a general replacement can "get you by" if needed. Let me know how this turns out.
Benjamin
Posted on Jul 27, 2009
Tip
Fix the ice maker and make it quieter
Hope this helps somebody and saves some time. My Electrolux EI23BC56IS8 fridge mfd 4/2011 quit making ice a couple weeks ago. It has through-the-door dispensing from ice maker in top-left of fridge. I pulled the ice bucket out and found a rubber tube snaked around the corkscrew auger inside and saw 2 small wires hanging down inside the ice maker cavity. On further investigation I found those wires went to some kind of sensor that plugged into a harness in the top of the ice maker. As I cleaned out the bucket, I found the plastic mount that was supposed to hold the sensor to the bottom of the ice tray had fallen off and was wedged into the grinder and chute that routes it all through the door.
I read that this problem has caused electric shock in others, so I guess I am lucky. What seems to have happened is when the auger was turning it snagged the sensor part that is attached to the bottom of the ice tray. It is held on only by zip ties. When it snagged that, probably with a chunk of ice, it pulled the sensor into the auger and that yanked the wires apart. Tracing the wires up into the roof of the fridge I could see they led to a flat plug, so they were easy to unplug.
I could not find just the wiring harness so I had to buy the whole assembly, including the top rails, sensor, wires, arm and the cube tray. It was part # 2 in the attached diagram. I got it locally for about $100, and it took about 20 minutes to install.
The next day we were pleased to have ice again. But, the fridge was making a racket now. The buzzing and humming was noisy. I traced that to the ice maker. After researching this issue it seemed to be ice build up clipping the fan blades in the fan behind the ice maker. It turns out I should have turned off the ice maker (door control panel) when I replaced that part. Duh. Also, 20 minutes or so of holding the door open made probably caused moist air to condense on the coils behind the ice maker. I could see ice behind the fan, and when I pressed on the fan motor between parts 33 and 24 in the attached diagram, the sound would change. (that fan is spinning fast and you can't see the blades so I carefully used a screwdriver to push the motor that can be seen through the opening. It's just like a computer case fan. Obviously plastic fan blades were hitting ice and it sounded like a buzz. That buzz would change tone as the fan sped up or slowed down periodically.
At first, I took a hair dryer to it, removing the ice bucket and blowing in the cavity for a couple minutes. The sound went away, but then it returned a couple hours later. Using a flash light I could see frost through the spinning fan blades, on the coils behind the fan. What I had to do, and it has been cured for 2 days now, is pull out the ice bucket, turn off the ice maker, get the hair dryer on high heat, and, this is the key, pull out a tube of aluminum foil to extend the reach of the hair dryer. Tubes of plastic would melt. I held the foil tube to the end of the hair dryer to get the air blowing right up against those openings in the back. I made sure to move the aim around so no plastic parts melted. The key is not just to melt the ice but to evaporate the water in there. It took maybe 5 minutes. Then, for good measure, I closed the door and let the temp equalize inside the fridge before re-inserting the ice bucket. So far so good.
on Apr 05, 2015 | Electrolux Refrigerators
I have a Samsung RF268ABRS Unit all food in bottom freezer thawed. Unit is running and ref is cool. I notice that the fan dosent seem to blow. Closed freezer up and its cold, but no air moving. How do...
I had a similar problem. my samsung freezer would only cool to 20 degrees, which also resulted in the freezer ice maker not functioning. (fridge door ice maker still worked) If you hold the power freeze and power cool buttons down together for 8 seconds it will a diagnostic. found the answers on http://appliancejunk.com/forums/index.php?topic=8206.0 , as too what the codes meant. Mine was throwing a freezer fan code error. ordered one online $30 and replaced it. seems to be working. TIP -The fan is located behing the rear panel in the freezer. I had two fans. The regular looking one is the freezer fan, the squirrel cage fan feeds the fridge ice maker. Also the new fan motors don't come with blades, just pull the blades off the old one and put it on the new motor. Don't push it on too far, make sure there is enough clearance so it spins freely.
Jun 28, 2011 | Samsung RF267AB (25.5 cu. ft.)...
Unit doesn't work when icemaker is on- Kitchen Aid Superba
that is unusual for the ice maker to cause it not to cool, but definitely not unheard of. if the fill tube to the ice maker, or ice maker itself, is leaking down the back of the freezer, behind the evaporator cover, it would form ice around the evaporator fan motor. this would cause the fan not to run, and the temp in the freezer and frige would rise. the ice would melt when it went into defrost, but then build up again. you should remove the rear panel in freezer and see if you see any ice build up around the fan blade, and if so, find where it is coming from. I hope this is the case for you. much cheaper than a compressor or new frige if it is. let me know if you have further questions. good luck, shane.
Sep 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer & fridge not cooling
Your evaporater fan should only be running when your compressor runs. if the fan is bad then it would indeed make the frig not too cold because it is not blowing air over the coils to remove the heat ,so it may need to be replaced. Also check coils to see if they need a good cleaning with a vacuum cleaner. Hope this helps
Jul 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
First, are you noticing any frost build up inside the rear freezer panel?
Are the fans and the compressor running?
Please let me know so I can assist you through this.
Vic
May 27, 2009 | Refrigerators
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Magic Chef RB19KA-4A not cooling. Compressor is running as I can observe frost on the copper tubing. Condensor coils were cleaned off of dust but overnight the freezer temp only got down to 45 deg F. Any...
It was determined to be a malfunctioning defrost timer. The freezer box bottom was removed (not an easy thing to do) and the coils found to be a solid block of ice. The timer would not start the defrost heater, hence the freeze up. The timer was replaced and the chill box is back in action.
Jul 22, 2008 | Magic Chef Refrigerators
Freezer not cold, the meat is melted
Sounds like you have a defrost problem. Pull the back panel off inside of the freezer and make sure the fan is running (evaporator fan motor). If it is, check the defrost heater and defrost thermostat for continuity. If one is bad, you have found your problem. If both are good, replace the defrost timer, adaptive defrost board, or main control board (I'm not sure which you have since I don't have your model number). Let me know if I can be of further assistance.
Mar 27, 2008 | Kenmore 53542 / 53544 Side by Side...
Squeeled, then hot on exterior
normally squeeling sounds from the freezer is evapurators fan motors... need to pull back panel off freezer and check out fan motor
Sep 03, 2007 | Whirlpool 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
