Question about Exceed-RC Dynamite Sava Red 1/10 Off Road Electric Truck
Exceed RC 1/10 4x4 truck transmitter or receiver problem
Everything seems to turn on and the lights light up normal. The truck doesn't respond correctly to the remote. The truck jumps forward when I try to turn the wheels. It doesn't respond to the throttle. The problem started to occur when my son snapped the the antenna in half. Can someone tell me what might be the problem.
  • 850 Answers
The antenna is not able to send the signal properly so repair or replace it
Posted on Jul 28, 2009
Where doI find the slot to recharge my helicopter
with most rc helicopters you have to disconnect the receiver unit from its battery and connect the charging lead to the battery lead the charger should have 2 leads 1 for the transmitter & 1 for the receiver
hope this helps
Aug 08, 2011 | xheli Exceed RC 24Ghz WarHawk 300 4Channel...
Acoustic Research Model AW871 wireless sterio speakers
Your connection between the AR transmitter and the ONKYO receiver sounds solid. I'd guess it's the wireless speakers that are the wrong point, or at least that's what I'd look at first. Doing a bit of research, I noticed a couple minor points. First, these seem prone to RF interference from other RF devices. Have to tried switching channels on them? Second, someone reported theirs would not work properly unless the speakers were turned on just before the transmitter, and turned off shortly after the transmitter. Apparently you have to hold the button on the front in for 5 seconds to turn the speakers on or off. I know that's rather basic, but it's been a few days and no one else has responded, so I figured we should start somewhere.
Aug 27, 2007 | Audio Players & Recorders
The fan/light will not come on with the remote. Yes remote batteries are new. The light fixture have power. I think the model # is JY97381. receiver # is UC7067RC. Unsure how to fix this problem. Can u...
Hello Susan,
If the indicator light on your hand-held transmitter lights up when you press the buttons, it normally means it's working. The problem is probably with the UC7067 receiver in the fan. One sure way to destroy the UC7067 is to have the power going to it controlled by a dimmer switch on the wall. If this is the case, replace the dimmer switch with a standard on/off toggle or an in-wall transmitter. You can find both a replacement UC7067 receiver and either another hand-held transmitter RC-210 or an in wall transmitter WC-210 at this address: http://www.fanmanlighting.com/shop/pc/viewCategories.asp?idCategory=57
Hope this helps!
Dec 11, 2010 | Minka Aire Ceiling Fan
Truck is new it ran for 2 hours and then stopped. The receiver LED light does not light up anymore.The ESC LED seams to function ok .It is blinking at a regular flash. It also beeps when you first turn...
Hi
The transmitter battery connections are dirty, oily or have come disconnected. Contact the manufacturer about a replacement transmitter. The charger sounds like it failed also. Was this purchased at a hobby store? They can help too..
Aug 12, 2010 | Exceed-RC RC Truck
Wont recieve signals
You more than likely got water on the circuit board. Try drying off the circuit board or get a new one
Jun 27, 2010 | Exceed-RC 1:16 Nitro powered truck,W/SH...
Why wont my Revo R.C. car respond to its remote?
Make sure batteries are good in the transmitter and receiver pack. Check antenna for damage.
Aug 01, 2009 | Traxxas Rc Revo Nitro Monster Truck
Doesn work at all
I've had the same problem. Get the technical assistance phone # out of the manual that came with the fan. They can give you the proper part # so that you can then call Home Depot and special order the receiver. However, I have done this and then installed the new receiver as advised by Hampton Bay and I still am unable to get the remote to operate the fan or the lights. I know the fan works becaue I bypassed the receiver and wired directly to house power. I don't know if perhaps I have a bad transmitter (remote). I'll try that next. The fan worked for about a year, now its just a headache.
Jan 30, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
Exceed-RC Dynamite Sava Red 1/10 Off Road Electric Truck Logo
488 people viewed this question
Top Exceed-RC Toys Experts
jasiel murphy
Tejodhar Atreya...
Tejodhar Atreya...
Mike Darragh
Level 1 Expert
Are you an Exceed-RC Toy Expert? Answer questions, earn points and help others
