Question about RCA 36V550T 36" TV
RCA 36V550T Television
TV keeps powering on and off intermittently.
  • Anonymous Nov 25, 2007
    tv continually zaps off. There is sound but no picture.
  • ronnie bradley Dec 03, 2007
    MY RCA 36V550T POWERS ON AND OFF UNTIL IT JUST WON'T POWER ON AT ALL. i THINK IT IS THE "GOODSKY RELAY" BUT I CAN"T FIND ANYONE THAT HAS THE RELAY. i FOUND THE GOODSKY WEBSITE BUT DIDN'T HELP ANY. ANYONE HAVE ANY IDEAS?
Why is my tv cutting on an off
If it is a RCA 36V550T do you hear a high pitched sound from set before you try to turn it on?
The model indicated is well known for the High Voltage transformer and or a sweep transistor failing.
The transistor is easy to check with a ohm meter and if shorted 100% chance it and the transformer are both bad (usually just the two parts)
Mar 26, 2012 | RCA 36V550T 36" TV
Trying to figuire out if the RCA 36V550T is Digital or analog?
That's a CRT... it's inherently analog. If you use the right equip, you could get a digital signal to display on it, but the picture would still be analog.
Aug 09, 2011 | RCA 36V550T 36" TV
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
My tv keeps shutting on and off
You television is having problems with intermittent component failure. The reason the television turns off and on is the protection circuit turns on when it senses high voltage or current level that may damage the internal circuits. The protection circuit turn the television off, the television will stay in this condition until the faulty component or components temporarily stabilize. When this happens the television attempts to turn itself on again. Once the component or components heats up it loses tolerances and again triggers the protection circuit to turn the television off. This is a problem that should be fully tested and evaluated by a certified service center. You can contact RCA customer support at this telephone number 1-877-947-7977 between the hours of 8am-8pm M-F EST and. 10am-7PM S/S EST. You can also contact RCA customer support on line at this web page link http://tv.rca.com/en-us/ContactUs.html I hope this information help you solve your problems with the television. Thank you for using FixYa and have a nice day!
Jun 20, 2009 | RCA R52WM24 52" HDTV Projection Television
36" RCA TV Wont power up
IP030 Regulator part number 263567/ Regulator overheating
Nov 29, 2007 | Televison & Video
TURNING ON
put batteries in the remote
Nov 13, 2007 | RCA 36V550T 36" TV
NEED HELP !!!!! remote will not work (original nor directv programed)
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
Sep 14, 2007 | RCA 36V550T 36" TV
RCA 36V550T 36" TV Logo
131 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
