Question about Car Audio & Video
Very little sound coming from driver side front and rear speakers, checked the balance and fade nothing is helping.vehicle is 2003 hyundai tiburon with infiniti sound system
    Problem Solver:
  • 9 Answers
The chance is maybe the speaker is blown, or wires crossed, if it is an aftermarket head unit, and or you use an aux cord to listen to an ipod or something like that as your music, that is most likely the auxilary cord is bad or cheap, happened with my car also
Posted on Jul 27, 2009
Driver side speakers fade in and out
Sounds like you may have a short in the wiring to the speakers. You can play with the balance and fade controls to check the sound, but a professional car stereo installer can troubleshoot and replace that for you.
Apr 13, 2014 | 2003 BMW 7 Series
What would cause the driver side front door speaker and the passenger side rear deck speakers not to work. When if fade the sound all the way to the front with no sound in rear and with the balance turned...
Check the speakers if they work. Connect the speaker terminals using a short wire to a 1.5 volt battery (AA or any dry cell batter) and listen if there's a thumping sound when the wires are connected to the battery terminals. If there's no sound, your speakers are busted. If there's a sound, check if the wires are okay. Use the same method with the battery with the wires from the back of your stereo. Make a small cut on the wire and attach the short wires you used earlier.
Nov 04, 2013 | Cars & Trucks
I have a 2003 Hyundai Tiburon 2.7L. Harmonic Balancer is loose. The car looses power. The serpentine belt comes off the pully. The vehicles starts but only the bottom pully turns I believe it is the...
sounds like the pully is spinning around the harmonic balancer the **** is broke i have same problem almost o rilley parts has one 50.00 bucks rent the tool to take it off and go to youtube to see how good luck
Jan 13, 2011 | 2003 Hyundai Tiburon
Im trying to connect my pioneer radio to my hyundai tiburon GT 2003, and i need to know what color wires on the radio go to what color wires on the cars wiring harness
Radio Constant Wire 12V+: Red
Radio Ignition Switched Wire 12V+: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Pink/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: n/a
Factory Amplifier Turn On Wire: n/a
Left Front Speaker Wire (+): White
Left Front Speaker Wire (-): Brown
Right Front Speaker Wire (+): Black
Right Front Speaker Wire (-): Yellow
Left Rear Speaker Wire (+): Blue
Left Rear Speaker Wire (-): Red
Right Rear Speaker Wire (+): Green
Right Rear Speaker Wire (-): Orange
Oct 06, 2009 | 2003 Hyundai Tiburon
2003 Hyundai Tiburon making a weird noise
Hello mpolci...The 2003 Tiburon was sold to the public with a defective clutch, it failed due to warpage and bad pressure plate... among other things. There are MANY class action lawsuits. Did you resurface or replace the flywheel when the clutch was replaced? Did you go with an aftermarket clutch kit, or factory? Also the slave cylinder on the 03 was known to have a defective valve.
You can try checking the levels and bleeding the system and if you still have problems, then it could be a release bearing, a loose clutch pad, or a broken pressure plate spring....If the clutch is still under warranty, i would return it to the installer.
Good luck, i hope this helps...please rate me a fixya.
Aug 01, 2009 | 2003 Hyundai Tiburon
Durango radio fade problems
Your front speakers are more than likely blown. They make all kinds of different models and price ranges to look at. This gives you a good opportunity to upgrade your stock speakers to handle what your throwing at it.
May 10, 2009 | 1998 Dodge Durango
Durango Radio fade does not work
check the connection atr the back if their ok or maybe you just have a loose wire on it...
May 10, 2009 | 2001 Pontiac Sunfire
Im trying to find where the inertia switch is
I'm not sure where its location is for this car but typically they are located in a couple different locations. Try on the drivers side access panel in the trunk. You may have to remove or pull the panel aside. Some other vehicles have them in the front passenger side kick panel.
Mar 29, 2009 | 2003 Hyundai Tiburon
Airbag light is on - 2003 Tiburon
section_closed.gif 2003 HYUNDAI TIBURON Recall ID from NHTSA: 02V290000 Auto Recall Date: NOV 05, 2002 Vehicle Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY Model Affected TIBURON Estimated Vehicles Affected: 7382 Recall Details Auto Recall Date: NOV 05, 2002
Vehicle Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY Estimated Vehicles Affected: 7382 Model Affected2003 HYUNDAI TIBURON
2003 Hyundai Tiburon Defect Summary:ON CERTAIN PASSENGER VEHICLES, THE DRIVER SEAT BELT BUCKLE WIRING COULD BE DAMAGED BY INTERFERENCE WITH THE DRIVER SEAT CUSHION HEIGHT ADJUSTER MECHANISM.
Defect Consequence:DAMAGED DRIVER SEAT BELT BUCKLE WIRING COULD CAUSE THE SEAT BELT WARNING LAMP OR THE SUPPLEMENTAL RESTRAINT SYSTEM (SRS) AIR BAG WIRING LAMP TO ILLUMINATE. IT COULD ALSO CAUSE THE AIR BAG FUSE (CAVITY NUMBER 5) TO OPEN, PREVENTING AIR BAG DEPLOYMENT. NONDEPLOYMENT OF AN SRS AIR BAG IN A CRASH WHERE AIR BAG DEPLOYMENT IS WARRANTED COULD INCREASE THE RISK OR SEVERITY OF INJURY IN A CRASH.
Remedy:DEALERS WILL INSTALL A NEW DRIVER SEAT BELT BUCKLE, IF NECESSARY, AND WILL PLACE A PROTECTIVE COVER OVER THE DRIVER SEAT BELT BUCKLE WIRING TO PREVENT DAMAGE FROM OCCURRING. OWNER NOTIFICATION BEGAN ON MARCH 24, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HYUNDAI AT 1-800-633-5151.
Notes: HYUNDAI MOTOR COMPANY 056
Dec 07, 2008 | 2003 Hyundai Tiburon
My l/r channel will not work
With the radio on u will need to push audio button it will change to something different on the face push until speaker balance comes up & then push butons below it left or right to balance each side of speakers. For me it was the left speakers that i needed to balance good luck John
Jun 06, 2008 | Pioneer DEH-1600 CD Player
Car Audio & Video Logo
91 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
