Question about Palm Zire 31 Handheld
My Palm Zire 31 was frozen on an appointment screen that I had set an alarm for. I have performed a hard reset, while holding the power button for 30 seconds, which unfroze my screen. However, I am having difficulty accessing features I select with my stylus. The problem seems to be I need calibrate, but I can not access the digitize feature. What should I do?
  • 3 Answers
Remove the Screen protector and then calibrate the screen with the stylus.
Posted on Sep 22, 2009
I would like to give my Zire 31 to a friend but need to erase all my information from it. How do I do this?
Do a HARD RESET on your PALM ZIRE 31.
A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings.
  1. Press and hold the Power (on/off) button on the front panel of your device.
  2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  3. If you see a progress bar (see below), keep holding the Power button.
  4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Jun 28, 2011 | Palm Zire 31 Handheld
How do i perform a hard reset on my palm pda
  1. Step 1 Straighten a paper clip into a single line.
  2. Step 2 Locate the "Reset" button by spotting a small hole on the backside of the Palm Zire 31.
  3. Step 3 Push the power button on the Palm Zire 31 with your finger and hold it down steadily.
  4. Step 4 Push the paper clip into the "Reset" button's hole while holding down the power button.
  5. Step 5 Release the power button once the screen displays the "Palm Powered" logo.
  6. Step 6 Push the navigational key in the "Up" direction to complete the Palm Zire 31 hard reset.
May 26, 2010 | Palm Zire 31 Handheld
Zire 71 screen does not sense stylus input -- even after performing a reset.
HI,
Try doing a hard reset. This will erase everything on your zire and restore it to brand new settings. To do a hard reset make sure you have everything backup on your palm desktop. Here are the steps for the hard reset:
1. Hold down the power button and then depress the small hole in the back with the tip of your stylus2.gif.
2. Continue to hold them both in until you see the Palm2.gif logo.
3. Let go of both of them and then follow the onscreen directions. You will want to answer yes and use the 5 way navigation button on the bottom of your pda and hit up so that is completes the reset. After that you will have to set up your touch screen and go through the tapping the target. After you have gone through all this then do a hotsync. It should clear up your problem. Best wishes.
Oct 10, 2009 | Palm Zire 71 Handheld
Hotsync
do you want to completely delete all the data on your palm zire if so try a hard reset (deletes everything!)
To do a hard reset:
Press and hold the power button on the front panel of the handheld.
1.
While holding the power button, use the tip of an unfolded paper clip (or
2.
similar object without a sharp tip) to gently press and release the reset button.
Wait for the Palm PoweredTM logo to appear; then release the power button.
3.
When a message appears on the handheld screen, warning that you are about
4.
to erase all the data stored on your handheld, press any other button to perform a soft reset.
Mar 16, 2009 | Palm Zire 21 Handheld
How do I make a hard reset on my Palm Zire 31 PDA?
There is a reset pin hole on the back of the unit; Hold the power button and push the reset button in the hole with a paperclip. All memory should now be erased.
Mar 26, 2008 | Palm Zire 31 Handheld
ZIRE: FROZEN THEN WHEN RECHARGED LOST ALL INFORMATION
I had exactly the same problem. I Hot Synched it with my computer (Ignore instructions for load cd) and everything returned as normal. Since this episode, I've learnt to hot synch more often than I was doing.
Jan 17, 2008 | Palm Zire 31 Handheld
Palm frozen - Won't Move
o at the back of ur palm is a reset button just press it and it should be fixed
Sep 07, 2006 | Palm Zire 31 Handheld
Can't synch Outlook Calendar Appointments
Try uninstalling with Windows Uninstall Clean-up tool. XP seems to do a poor job of installing conduits sometimes. I think this might be an issue with the one conduit no being registered correctly in the Windows Registry. You can get this tool here: http://support.microsoft.com/default.aspx?kbid=290301 Uninstall Palm Desktop. Then shut down the PC. Then start it up again and re-install Palm Desktop. I hope this helps.
Sep 11, 2005 | Palm Zire 31 Handheld
Palm Zire 31 Handheld Logo
267 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
