Question about Rowenta Power Duo Iron
The cord is worn out where it connects to the iron and sparks flew when using most recently...
    Problem Solver:
  • 16 Answers
You have a broken wire. unplug the iron, you should be able to remove the cover. you can repair the wiring or replace the chord.
Posted on Jul 27, 2009
When I plugged iron in sparks came out at wall and iron where the cord connects.
If you've had this iron for a while it sounds like the cord may be frayed.
switch it off at the wall and unplug it, check the cord for wear, if the insulation is frayed, torn or broken and there are black burn marks on the cord where you saw sparks then the cord needs to be replaced.
DONT plug the iron back in until the cord is replaced.
Otherwise If there are no breaks or black burn marks on the cord, then your power point may be faulty and needs to be replaced!
I hope this was helpful
MobileJB
Jul 13, 2011 | Oreck Cordless Speed JP8100CA Iron
I have a B&D 2030 steam iron which I really like, but recently it isn't always turning on when plugged in. I think there may be a short in the cord somewhere, possibly the plug?? It seems to work...
Likely the wire inside the cord is broken from lots of use. You can usually tell where by turning the iron on while plugged in and bending the cord. You will hear a spark when you bend the spot with the break. It isn't very difficult to replace the cord with a new one.
May 31, 2011 | Black & Decker D2030 Iron
Iron shorted out, sparks and blew a circuit breaker in room
Depends on where the sparks came from. If it was from the cord then yes, fix the cord. If it came from inside the iron then, maybe. You would have to open iron and see what caused it. If you are and electrician or technician then you could measure resistance and find problem.
May 07, 2010 | Rowenta Effective DX1900 Iron with Auto...
Iron cuts off in the middle of ironing
It is probably an intermittent cord connection next to the strain relief. You can simply remove the back cover, cut the cord, pull the remaining cord (approx 6-8") and reconnect it. You can also order part # RS-DE 245954 the whole cord assembly including the circuit board for about $25.
Apr 17, 2010 | Rowenta Irons
It suddenly quits...i have to juggle the line cord to have a power.
Sounds like a loose connection from the screws inside the housing of the iron. It is a wee bit of a bugger to get INTO this iron, but with a little patience, and a screwdriver (phillips, the + one) you should be able to get to where the power cord connects to the terminals inside the iron. Loosen, and retighten the connection. If the wire seems 'worn', you may have to cut it back a bit and score off some of the plastic, and re-wire.
Mar 17, 2010 | Euro-Pro Shark GI490 Iron
I replaced the badly worn cord on a Phillips steam iron and everytime I switch it on it throws the circuit breaker. I am assured that the iron was working OK before I replaced the cord, but because it is a...
There is a break in the insulation somewhere and tge wires are getting crossed or the active wire insulation is broken and it is shorting to the eaarth ground.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jan 23, 2010 | Micro Pro 7599 Iron
Cord burst into flames / daughter almost electrocuted
As with any appliance, they should be checked on a regular basis. Quite often the cord becomes damaged where the insulation becomes worn with the constant movement and friction against the iron and board. The copper strands must have sheared inside the cord causing a spark to ignite the rubber. she did have a lucky escape. I expect the water came out when she dropped the iron
Sep 21, 2009 | Euro-Pro Shark GI490 Iron
Shark GI495N cord sparked and burst into flame
shark website for instructions and number
May 07, 2009 | Euro-Pro Shark GI490 Iron
Why isn't my Iron heating up? will not heat
well..let's check the plug..is it firmly in wall, and ** problems with the part going into the unit, as well?
does the light that shows power work on the panel, under the handle?
has the unit dropped recently?
Mar 10, 2008 | Rowenta Powerglide DM273 Iron
Rowenta Power Duo Iron Logo
239 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
