Question about InstallShield Update Service Version 3
1995 mustang safety switch tool?
I am trying to replace my safety switch and am having problems locating it. it my be in a sensor and if so i'm told i will need a special tool for the sensor. it is an 1995 mustang 3.8 automatic.
  • 41 Answers
Look on ebay?
Posted on Nov 29, 2007
Where is the fuel pump relay located on 1995 Ford Mustang Cobra?
Under the hood with the main fuses on the left hand side. Just in front of the master cylinder. I would check the safety switch located in the trunk on the left side behind the wheel well fabric. Should be a yellow button.
Oct 12, 2014 | 1995 Ford Mustang
Car wont start after accident
Alot of vehicles have a safety fuel shut off when wrecked you have to locate this and switch it back for the car to start....i wrecked my 05 mustang and it wouldnt start my husband located the safety fuel cutoff thing in my trunk behind the carpet in like the fender wall
Feb 21, 2012 | 1995 Mercury Villager
I have a 2001 ford mustang and i am trying to locate fuel pump relay switch, i was told in fule box # 14 but fuel dialog box dont correctly identify
The fuel safety switch is located in the trunk on the drivers side just forward of the tail light.
You'll have to remove the drivers side trunk carpet liner to gain full access to it.
Aug 19, 2011 | 2001 Ford Mustang
I disconnected the clutch cable under the dash of my 95' ford mustang gt and connected it back and now it will not turn over or start at all. All the fuses are good and have power, what could it be?
check the neutral safety switch located near the top of the clutch pedal, probably knocked the wires off, if you need more help get back to me
Mar 25, 2011 | 1995 Ford Mustang
P0705 Trans Range Sensor Circuit Malfunction PRNDL Input
I would check the neutral safety switch. It's located on the shift shaft of the transmission and is known to go bad
Sep 18, 2009 | 2003 Ford Mustang
Looking for the neutral safety switch
Neutral Safety/Back-up Light Switch
This is a combination switch which controls both Neutral Safety and Back-up lamp circuits.
C6 Transmission
C6 neutral start switch
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle on jackstands.
  3. Remove the downshift linkage rod return spring at the low-reverse servo cover.
  4. Coat the outer lever attaching nut with penetrating oil. Remove the nut and lever.
  5. Remove the 2 switch attaching bolts, disconnect the wiring at the connectors and remove the switch.
  6. Installation is the reverse of removal. Adjust the switch and tighten the bolts to 55-75 inch lbs. (6.2-8.5 Nm).
  7. Remove the jackstands and lower the vehicle.
  8. Connect the negative battery cable.
AOD Transmission
Removing the AOD neutral start switch
  3. Disconnect the wiring from the switch.
  4. Using a deep socket, unscrew the switch.
  5. Installation is the reverse of removal. Tighten the switch to 10 ft. lbs. (14 Nm).
  6. Remove the jackstands and lower the vehicle.
  7. Connect the negative battery cable.
4R70W Transmission
Removing the Manual Lever Position (MLP) sensor
As of 1994, the neutral safety switch is referred to as a Manual Lever Position Sensor (MLP).
  3. Disengage the harness connector from the MLP sensor.
  4. Remove the 2 sensor attaching bolts and remove the sensor.
To install:
  1. Install the MLP sensor and install retaining bolts. Do not tighten, the sensor requires adjustment.
  2. Adjust the MLP sensor then tighten attaching screws to 80-100 inch lbs. (9-11 Nm).
  3. Remove the jackstands and lower the vehicle.
  4. Connect the negative battery cable.
ADJUSTMENT
C6 Transmission
  1. Hold the steering column transmission selector lever against the Neutral stop.
  2. Move the sliding block assembly on the neutral switch to the Neutral position and insert a 0.091 in. (2.3mm) gauge pin in the alignment hole on the terminal side of the switch.
  3. Move the switch assembly housing so that the sliding block contacts the actuating pin lever. Secure the switch to the outer tube of the steering column and remove the gauge pin.
  4. Check the operation of the switch. The engine should only start in Neutral and Park .
4R70W Transmission
Adjusting the MLP sensor
Park is the last detent when the manual control lever is full forward. Return 2 detents toward the output shaft for Neutral.
  1. Position the manual control lever in Neutral .
  2. Insert Gear Position Sensor Adjuster tool T93P-700 10-A or equivalent, into the slots.
  3. Align all 3 slots on the MLP sensor with 3 tabs on the tool.
  4. Tighten the attaching screws to 80-100 inch lbs. (9-11 Nm).
I hope help you. Good luck (rated this help).
Sep 17, 2009 | Ford E-250 Cars & Trucks
1995 Ford Mustang Engine Won't Turn Off
the ign switch should take care of it i agree with you
shack
Apr 18, 2009 | 1995 Ford Mustang
InstallShield Update Service Version 3 Logo
82 people viewed this question
Top InstallShield Computers & Internet Experts
Robin Hill
Robin Hill
Alex Krenvalk
Alex Krenvalk
Jon Slaton
Jon Slaton
Are you an InstallShield Computer and Internet Expert? Answer questions, earn points and help others
