SOURCE: correct procedure for charging battery
Batteries no longer have a memory problem so charge away. I plug mine in every night and have never had a issues.
SOURCE: "use genuine battery" message
Because you are using a battery with more mAH your phone is not getting it. Have you got the same from LG, if so ask them for compatible battery. If not don't try such things. Better you get two batteries of lower mAH.
SOURCE: why won't my new alternator charge my new battery
the power wire for that lays on top the intake probly has bad spot drawing out the current
SOURCE: how do i resolve the error: use genuine battery. power off
A temporary fix to the problem is to put the battery in the freezer for a minute and then put it back in the phone and it will turn on just fine! I had an LGVX8700 and it just randomly started happening one day and my fiance told me to try doing that so i did and sure enough it worked. I had to go to verizon at one point to get a new phone because the one i had got damaged and the tech there used the same battery in my phone for the new one and he thought i was crazy when i told him to put the battery in the freezer but he was in for a surprise when he did what i told him and my phone turned on. It's annoying because you have to do that everytime your phone shuts off but i always made sure i plugged it into the charger before it went completely dead.
