I have a suncutter outside air unit and the fan barren has broken and i need a new fan for this unit I have the model # can you tell me where to locate one
    Champion:
  • 233 Answers
Generally speaking the fan motor will have to be removed and taken to an appliance repair supply house. The unit model number will need to be written down and taken with you, but it is best to compare the motors when purchasing.
Posted on Jul 27, 2009
Looking for heat strips for a Coleman Suncutter model#1436-901 air conditioning unit. Are they still available?
Look on heater strip to determine wattage . Most heater strips are 5000 watt . You can buy a kit to restring heater (just pull out burned wires and install new ones from kit for a good as new heater and much cheaper )
Oct 01, 2014 | Heating & Cooling
My rheem a/c unit turns on but the outside fan does not ? is there a reset button on the fan? we had an electrical storm
You need A new run capacitor that is found in the outside unit it is silver in color and tells you on the cap what micro farad it is for example 45+ 5.
Sep 07, 2014 | Heating & Cooling
I have a coleman suncutter model 7448-801 and the fan motor was replaced but instead of it blowing out the top of unit it is drawing in from top and trying to blow out thru the coil is this accurate or is...
I have never seen one that doesn\'t suck air in through the coil and blow out the top. My guess is that the double shafted motor was installed backwards.
May 09, 2014 | Heating & Cooling
THE FAN IN THE OUTSIDE UNIT IS NOT WORKING. INSIDE UNIT RUNS BUT NO COOL AIR IS COMING OUT OF VENTS. IS THERE A REST BUTTON OLN THE OUTSIDE UNIT?
either the fan has went out or the capisitor for the fan is bad and needs to be replaced.if you have run the outside unit very long without the fan turning you might be replacing the compressor as well as the fan or capisitor.if the fan isnt pulling air through the cond coil outside,the compressor gets very hot very fast,and it locks down(burns up). get it looked at asap before it cost more because of other broken parts caused by the fan not working.
Sep 24, 2010 | Bryant Heating & Cooling
Panasonic air conditioning model no cu-v9ckp5 inside unit switches on but no fan operation outside unit starts then after approx 1 min whole thing shuts down again
The outside unit has a fan capacitor and it must be faulty!!! thae capacitor tells the fan to rotate and if the fan does not work then the compressor will shut down due to a high head pressure and temperture!! change the capacitor located in the electrical section of the outside unit and it should work fine...
Sep 10, 2009 | Heating & Cooling
House HVAC Not Blowing
If the outside unit is running and the inside unit is not, probably a problem with the fan motor itself or its capacitor. If you have to have someone repair or replace the fan $200-$250 with parts, a capacitor for a service call and part $100 or so. Check it yourself first to see if there is anything obvious broken wire, hot connection, etc if you feel safe doing that. Turn the power off first. There is also a chance the thermostat could be the problem. Have you tried running the fan on the thermostat "fan on" setting?
Jul 01, 2009 | Goodman Heating & Cooling
We have a new house and it came with central air. I have turned on the air and turned on the circuits and noticed that the outside fan on the outdoor unit was spinning round (good) now, I checked and the...
yes indeed Id have to say the motor hasent been oiled....call a hvac guy and see how much theyd charge ya for maintenance call and decide then as if its priced right for you. after the inspection he'll tell you "XXXX" is wrong and you need this or that.
Jun 23, 2009 | Heating & Cooling
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
