Question about GE Spacemaker JVM1640SJ Microwave Oven
Reinstallation of microwave on tile - template or picture?
I took the GE Spacemaker Microwave oven off the wall to tile behind it. Now we need a template or picture showing how to rehang it
    Problem Solver:
  • 18 Answers
Contact GE with modle number and they will send you one
Posted on Jul 28, 2009
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
How do I install a GE Spacemaker Microwave oven?
It depends on where you want to install it. Thet usually go below the cabinetts which are over the oven.
IOt should have come with a template so that you can drill holes into the bottom of the cabinett so the holes you drill will match up with the holes in the microwave. Once done then there should be screws and fiber washers.
Good luck,
Marty
Jun 12, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
I need the Top Cabinet Template and the Rear Wall Template for GE Microwave Model JVM2070WH02
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Apr 24, 2013 | GE JVM2070 Microwave Oven
I need Template and installation instructions for GE Spacesaver Microwave Model JVM1630CJ02, built Jan 2005. Thank you.
You can download GE owner's manuals and installation instructions here.
If the installation instructions do not have the template, you can also find helpful exploded view diagrams and order needed parts by entering your full model number here.
Apr 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Wall template mount for ge profile microwave
You can may be able to order that by looking up parts by your full model number here.
Jan 10, 2010 | GE Profile Over-the-Range Microwave
How do I remove an old wall mounted Microwave.
I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
Mar 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave - No lights, No fan, all else works great!
sounds like you have a bad control board.. part# WB27X801 this is located behind the touch pad..
Apr 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Nov 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Removal
There are 3 mounting screws that anchor the microwave to the cabinet above it and a bracket on the wall behind it. Once you remove the mounting screws from the top, pull the oven straight out from the front and it will slide off the wall bracket.
Nov 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
596 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
