Everything on the screen that should be black in color is now
Everything that should be black in color is now red with red also coming out in different places
    Sergeant:
    Novelist:
  • 192 Answers
If the monitor is a CRT, then there is not much you can do. The guns are in misalignment. If you do have one and want it fixed, then take it in for repair. If you open a monitor and try to adjust the phosphorous guns, it can kill you.
If it is an LCD, just get a new one because unless it is under warranty, it's just not worth it.
Posted on Jul 27, 2009
  • 724 Answers
Reseat the monitor to computer plug or try a different monitor.
How do I get the printer to print when it only has the blk ink cartridge that is new and the color ink is running out. It prints everything red. What do I do?
Get new color cart. Most inkjet printers will not print anything if one of the carts is empty.
As for printing everything red, that is a different issue. Your printer setup screen in the computer may have a "black only" setting.
Nov 09, 2015 | Cannon Office Equipment & Supplies
My color on t.v. for everything that is green comes out grey. mostly my color is red. what do i need to do?
TAKE SET to black and white program and in menu turn color all the way off:
WHAT COLOR IS THE SCREEN? RED? If so I can tell you what to do.
SD TECH
Sep 09, 2010 | Hitachi 51F59 51" HDTV Projection...
Black ink printing red
Some printers only use the black ink to provide a darker black. They also use the other colors to print black. That is they use all three to come up with black. If you color cartridge is out of two of the colors, you may be getting just the red. Otherwise you may have a hardware problem.
Jan 29, 2010 | HP PSC 1315 All-In-One InkJet Printer
HI,the color on my monitor has gone blueish its like
try reseating or/replacing the cable. If the connection isn't good then you can lose one of the three basic color channels resulting is a tinted screen color
Jan 08, 2010 | Acer AL1916B 19" LCD Monitor
F25216bc RCA 25 inch TV. Color is distorted with a heavy red tint
You either have a bad CRT or a Shorted Red Output IC/Transistor. One other possibility is if
someone turned the Screen Control down if it is accessible from the back of the set.
Hope this helps,
Skyassc
Jun 22, 2009 | RCA F25216BC 25" TV
Black and white
Your not getting color probably because of a weak "air" signal. The fix is a better antenna or an antenna booster.
May 08, 2009 | Apex Digital PF2025 20" TV
Display Problem Black turns Red
sounds like you have a loose connection ....either into the screen or into the motherboard....the connection between board and screen runs through the hinge brackets and often comes loose after machine has been opened and closed a lot.....need to be comfortable opening up laptops to check the cables as it can be tricky to get to the back of the screen where the end of the ribbon cable is..
Dec 13, 2008 | HP Compaq Presario V2000 Notebook
the is some loos connection in the staip comming from lcd to motherboard.
check it.
Nov 24, 2008 | Computers & Internet
Screen is not clear ( red color is not there)
Check the cable for kinks at either end. VGA cables that are bent at a 90degree angle for lon periods of time become damaged. The next step is to remove cable from computer and check the pins for damage. A bent pin from accidental force from inserting and seating connector can catch a pin and contact with another pin or ground. If none of these conditions exist, consider monitor replacement. I would try another monitor to rule out the video card as well.
Apr 28, 2007 | LG Studioworks 552V 15" CRT Monitor
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
