Question about Carrier Heating & Cooling
Thermostat works but ac does not turn on - Carrier Heating & Cooling
    Problem Solver:
  • 9 Answers
Your T-stat has a battery for a back up. If you feal no air blowing, check power to your unit, if theres power it then could be blower motor, capacitor, a number of things.
Posted on Jul 27, 2009
    Problem Solver:
  • 16 Answers
I need more info.....type of A/C, is the fan blowing or just not cooling or none of the above. have you checked the power, from the breaker to the unit
Just purchased 1993 coachman RV heater works but ac doesn't ac did come on yesterday morning when wife turned up thermostat because she was cold
check for a problem climatic control unit
if the ac gave out cold air when the thermostat was adjusted , it indicates a control problem rather than an ac problem
take it to an accredited ac specialist shop for a proper diagnosis and quote
Jul 29, 2016 | RVs
Would a closed thermostat stop the radiator fan from turning on when the temperature is within heat range.it turns on when I turn ac on,is that a different cause when not using ac.
There are two different thermostats--one in the cooling system, and one just to turn on fans. The AC has a separate circuit to turn on fans regardless of engine temp, so tind the the fan thermostat and test it.
Jul 03, 2016 | AC Cars & Trucks
Ac will not turn off
You might want to check the thermostat settings and try to set those as hot as possible to see if the ac turns itself off. If this does not work the first suspect for replacement is the thermostat.
Oct 25, 2015 | Arctic Cooling Computers & Internet
No fan when ac kicks on Ihave a eb15b funace with a coleman ac
The heat will normally use a low speed on the fan, & the AC along with the fan switch on the thermostat will use the high speed. The thermostat turns that high speed on when there is a call for cooling & is the same switch if you were to manually turn the fan from auto to on. Try turning the fan on @ the thermostat. If it works, then replace your thermostat. If it doesn't, it could be a bad fan speed, a bad fan relay on a control board or external relay, or a loose or broken green thermostat wire.
Apr 14, 2014 | Coleman Home Electric Furnace Eb15b/Eb15d
AC has stopped working. CT3500 thermostat. Had "replace battery" indicator on. Replaced batteries with fresh new ones. Now the blower is not working when AC is on. If I set the thermostat to Fan ON,...
Possibly - the fan is supposed to work in conjunction with the compressor. Otherwise the evaporator will freeze up.
Check to see if the thermostat can be reset to factory defaults because it definitely is not working right.
Sep 14, 2017 | Honeywell Heating & Cooling
My thermostat says -AC WHAT DOES THAT MEANB
Turn your fan from auto to on at thermostat, fan should come on. If
you still get the (AC) and fan does not come on, change the batteries at the thermostat if they have them..
To see if thermostat is bad, do this.
1) Turn power off to Furnace/AirHandler.
2) Remve Bowler Door and find where thermostat wires connect to control board. Remove wires and write down which terminal they go
to.
3)Take a wire and hook-up between R and Y. Put door back on, turn power on. Fan should come on and AC should come on.
Jul 11, 2010 | Goodman CLQ36AR49 Air Conditioner
New thermostat..have heat but not A/C help....
What are you setting the thermostat to when you turn on the AC , if you turn on the AC and the house is warm you will need to turn the AC down to a lower setting before the the AC will start up.
Mar 14, 2010 | Honeywell Electronic Programmable...
Heating & Cooling Logo
67 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
