Text from manual below. Pictures of manual attached.
TO"LEARN" A FIX CODE PROGRAM FROM ANOTHER UNIT:
1. Press and hold both buttons (1 & 2) on the SPR. The LED will flash three times. Keep holding {for about five
seconds) until the LED flashes again (twice), indicating that it's ready to duplicate your garage door opener's
code. Release both buttons (Fig. 1 ).
2. Place your existing garage door remote and the SPR unit within an inch of each other. Press and hold the
first button on the existing unit while pressing button 1 on the SPR unit. The LED will flash, indicating that it
is learning. Keep holding the buttons until the LED light goes out. At this point, the SPR unit has duplicated
the code (Fig. 2).
3. Follow Step 2 to duplicate another code.
4. Exit the learning mode after duplicating codes by pressing and holding both buttons on the SPR unit. The
LED will flash once to indicate that you have exited learning mode. Examine the unit to see if your codes
were duplicated completely.
TO EXAMINE CODES:
If the remote is programmed correctly, the LED stays lit while the button is pressed.
If code duplication has failed, the LED will flash when the button is pressed. Follow Step 1 again if duplication
has failed.
TO LEARN GENIE ROLLING CODES:
Genie rolling codes require special additional instructions to program. Once step 1 through step 4 of the Fixed Code
Instructions are completed, you must do the following:
A. Pra•ce the SPR on the top surface near the rear of the original Genie
Remote instead of setting the two units side by side during Step 2 of the
Fixed Code Instruction; shown as Fig. 3
B: Press the Learn Code Button on the Genie Unit. The LED on it will keep
flashing.
C: Press the program button on the SPR. The LED on the Genie Unit will stop
flashing and become a solid glow
D: Press the same button on the SPR for the second time- turning off the
LED light on Genie Unit and finish the Genie Code Duplication.
E: Follow the EXAMINE CODE section of the fixed code instruction to test code duplication.
F. Follow the above steps if you wish to duplicate another Genie Code on your SPR.
NOTE:
If the first time you only programmed one button on your SPR, and you would like to program the second button later
on, either with FIXED CODE or GENIE ROLLING CODE, you will have to REPEAT step one of the fixed code
instruction to enter the leaning mode; then follow the instruction listed previously. After duplication, you will have to
repeat step 4 of the fixed code instruction for exit learning mode as well. This is very important.
