Question about Whirlpool Washing Machines
I have opened the lid and unscrewed the lid contact but now i cant find where the connecter is at how do i get to it?
    Scholar:
  • 76 Answers
Is this a older model whirlpool..Like a regular traditional topload. and you unscrewed the 2 screws holding the lid switch. If so, you need to unscrew the top councel. 2 screws on the back of the councel at the corners. unscrew, then flip top councel over. then youll see some clips holding the back panel to the whole cabnet. unclip the, with a flat head screwdriver and then the whole cabnet should come off..lift it a little and pull towrds you and you switch should be hanging under the cabnet somewhere if you look under the cabnet..like i said if this is the traditional top load washers....i would need a model number tho to see...but if it is jus put it back together how you took it apart and make sure you dont kink the clear hose when you put the cabnet back into place. Make sure the cabnet seats right on the frame at the bottom..hopefully this helps...
Posted on Jul 27, 2009
Whirlpool cabrio washer WTW5500XW1. Washer starts then lid lock starts blinking and nothing happens.
Bad lid lock activator....try taking some contact spray...and open lid find contact that goes up and down in lid closing area ...spay contact spray then open and close lid 5 times and try it...
Aug 13, 2016 | Whirlpool Washing Machines
Locked out of trunk 2000 cadillac eldorado release button not working i removed lock on trunk still cant get in trunk
Pressing the rear compartment lid release switch provides an input signal to the instrument cluster. The instrument cluster sends a Class 2 serial data message to the body control module (PZM). The PZM grounds connector C6 of the rear compartment lid release solenoid through CKT 1344 (LT BLU) if the following conditions are present:
The transaxle is in the PARK position.
The valet lockout switch is closed.
Power is supplied through the following components to the now-grounded CKT 1344 (LT BLU):
The RADIO/PHONE fuse
CKT 40 (ORN)
The coil of the rear compartment lid release relay
The relay coil energizes and closes the relay contacts.
Power is supplied from the CONVENIENCE fuse through the following components:
CKT 2040 (ORN)
The now-closed relay contacts
CKT 56 (BLK/WHT)
The rear compartment lid release solenoid
The solenoid energizes and the rear compartment lid latch assembly releases the rear compartment lid.
Did you perform the rear compartment lid release system check?
Go to Rear Compartment Lid Release System Check
  1. Place the transaxle in the PARK position.
  2. Turn the valet switch OFF.
  3. Connect the scan tool to the data link connector (DLC).
  4. Turn the valet lockout OFF.
  5. Press the rear compartment release switch.
Does the body control module (PZM) command the rear compartment lid release ON?
Go to Step 3
Go to Step 7
  1. Disconnect the rear compartment lid release relay.
  2. Connect a test lamp between terminal D4 and ground, and terminal D6 to ground.
Does the test lamp light at both terminals?
Go to Step 4
Go to Step 14
  1. Connect the test lamp between terminal D4 and terminal C6.
  2. Press the rear compartment lid release switch.
Does the test lamp light?
Go to Step 5
Go to Step 15
5
Connect a fused jumper between terminal D6 and terminal C4.
Does the rear compartment lid open?
Go to Step 6
Go to Step 16
6
Replace the rear compartment lid release relay.
Does the rear compartment lid release operate properly?
Go to Step 7
If you don't know what your dealing with there is no way you can fix it . I suggest you take it to a qualified ASE certified repair shop or the dealer !
Aug 24, 2015 | Cadillac Cars & Trucks
Htc wildfire s touch screen randomly selecting things
I solved the problem!
Description of the problem: my touchscreen went crazy (it selected random thins, especially in the bottom region of the screen) quite often and every time i had to lock/unlock the phone in order to fix it... but after 30 sec the problem went back!
Solution: remove the back lid cover, the battery and the sd card; unscrew the 5 screws and remove the second plastic lid; behind the battery slot you'll see three metal flap: when I opened my phone one of them wasn't in contact with the card! I fixed it and I cleaned these three contact with alcohol! Now my Wildfire S works fine!
Nov 25, 2012 | HTC Wildfire S Smartphone
Lid lock indicator flashes and washer will not spin
The lid lock switch is defective and tthough the lid is closed the contact is not short . This connection must be establised as the safety feature when lid is opened to stop the motor from rotating.
So remove the lid switch which is fixed on the hinges section and a possible contact spray can rectify the switch contact. If not replace and set for the washer to spin.
Sep 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washer says du and it wont come on! the door lock keeps clicking like its tring to lock but cant
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 16, 2010 | Whirlpool Washing Machines
Location of thermestat on 2.0 motor vw golf
Heading towards the front right on the engine by the water pump belt spin, leading to the 3 very thick tubing (sitting on top). The header tank lid open. Then disconnect the lowest of the three tubes, but assume a prior trough. Cooling water can expire. Then unscrew the lid, which was connected just deducted this hose. If two Sechskantaschrauben SW10. Among them sits the thermostat, pull them.
Dec 27, 2009 | 1997 Volkswagen Golf
The lid over the container for the detergent won't open. I can manually open it, but it won't open on its own. this is a new unit.
please check it if they have locked it.and in some models the lid will be form of screw we should unscrew the lid.please try it.
Nov 07, 2009 | Dishwashers
Washer stopped working - dryer ok
I checked the electrical schematic and the only thing that made sense was the lid check switch. Opened the top of the washer, checked the switch and it was not working. It is the switch shown below. The red button was not up therefore it is broken.
Just to make sure I bypaased the switch with a jumper and made the washer work.
You can order the lid switch online at partselect.com, the part number is PS60679 and it costs $10.38 plus shipping.
Here is someone else's experience with the same switch.
Washer was dead and would not turn on Overall Rating:
Helpful
Rated By:
6 Customers
Posted By:
Suleman From Canoga Park CA
Posted:
05-21-08
Appliance Repaired: Maytag Washer
Model: onceuponatime...
Age Of Appliance: 1 - 4 years
Well the washer died and would not turn on in the middle of a wash cycle. Absolutely dead. I disconnected it from power and opened up the front panel on which all the control switches and knobs are mounted. This is removed by unscrewing 4 screws at the top of the washer.
Checked the fuse, and found blown. Replaced the fuse, closed the panel and plugged it in. Still not working. Checked the Check switches and found the Check Switch really limp. Checked with Digital Multimeter and found no continuity at either position. Unscrewed the check switch. Removal and re inspection with DMM of the check switch confirmed it was bad. Opened up the check switch and found contacts were blown.
Installed a new check switch making sure all the connecting wires go in the right places. The wiring diagram in the washer was very helpful in doing so since u dont want these wires reversed. Adjusted the plunger which operates the check switches when the lid is opened to make sure it is not over or under operating the switches. This is done by loosening the bolt holding down the check switch assembly and slidint the whole assembly forwards or backwards till the plunger has just enough push on the switches. This is done to avoid the plunger from exerting excessive pressure on the check switch and the safety switch in lid open or lid closed position. (both switches are operated by the same plunger according to the lid position)
Closed panel cover and plugged the washer in. There u go, it was alive again!
Parts Used: Lid Check Switch Level of difficulty: Easy Time to do repair: 15 - 30 mins Tools: Wrench set , Screw drivers
Jan 11, 2009 | Maytag LSE7806A Top Load Stacked...
Frigidaire FWS833A Top Load... Problem
lid switch also function as safety lever lock. its a 2 way lever contact switch. replace it.
Apr 20, 2008 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
