Question about Brother MFC-5440CN All-In-One InkJet Printer
Only Button lit is Fax
The only button that is lit on the unit is the fax button. When I press any other button the unit beeps two or three times.
  • 832 Answers
Power off machine by pulling out the electrical plug.
Wait three minutes. Plug in machine to power. Wait until machine has finished its set-up.
Now you should be able to change the programms (scan/fax/copy)
Set Date and time and in case, your fax nr.
Posted on Nov 23, 2007
I am using a printer of brother mfc and i can not understand how to fax from it
The default setting on Brother MFC printer is Fax. Meaning you will usually see the Fax Button lit with a green light. (If the fax button is not lit, just press that button to get it lit.). Put the sheet of paper you want faxed with the side you want sent face down. Now press the OK button. The screen will ask you to enter the Fax number. Key in the Fax number. Press start. The printer will start scanning that page. Once the first page is scanned it will give you 2 options. You can press 1, if you have more pages to send to the same Fax number. or you can press 2. This will tell the printer(Fax) it is just a 1 page document and the machine starts dialing. Wait for the fax completed message. Please make sure that the machine is connected to a working phone line before you start.
Aug 13, 2010 | Computers & Internet
Please tell me how to change my Brother Fax 1020 Plus to receive faxes only. At the present it is receiving both fax and phone calls.
for dedicated fax use you have to press "Mode" button repeatedly until on the right side of the display it appears "FAX". Now you should have "F/T" on the display and you must press "Mode" button three times.
Sep 07, 2009 | Brother Office Equipment & Supplies
How do you program the machine to recognize the incoming fax ring tone
if it is a sharp fax machine it has a reception button which you could change the status of unit from telephone to fax or answering machine. usually the indicator of these button is located on the rightmost portion of the lcd screen. once you press the reception button while the unit is on standby, the indicator will point on which of the three settings will you want to activate.
May 12, 2009 | Office Equipment & Supplies
Brother fax 4750e can not receive or send fax. sender said the line just ring and ring endlessly
To set up for receiving Fax, do the following:
Press Mode button repeatedly untin Fax and Fax/Tel lights are lit.
Faxes will automatically print and answering machine will take the calls. If you have a dedicated fax line, do the following:
Press Mode button repeatedly until just the FAX light is lit. Then the machine will answer every call as a fax.
Apr 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother intel 1279 fax. The phone rings but the fax does not com
Press the Mode button that has TEL/FAX , TEL , FAX. Press the button until the light beside the FAX mode is lit up. That is it! Should pick up on its own. Hope this worked for you!
Apr 10, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Key pad on brother 1020e fax mc seems to be locked when you press copy for ex it just beeps 3 times
When the Brother machines beep three times while pressing any button on the front panel, this means there is a button stuck. Try pressing all buttons over and over to unstick button. This should help. Please rate my help if this works. If you need anything else, save my user name and ask me anytime. Thanks!
Jan 21, 2009 | Brother FAX-1020e Plain Paper Thermal...
Brother MFC 8500 receives faxes and does nothing else
Check to make sure that the PC Fax Function is turned off. I noticed after I connected the 8500 to my PC and installed the software, I too could no longer receive faxes and it was corrected after I turned this PC Fax function off.
The function is located by:
  1. Press the MENU button.
  2. Select Option 2.
  3. Select Option 1.
  4. Select Option 8 (PC Fax) and turn that function OFF.
Hope this helps!
Apr 28, 2008 | Brother MFC 8500 All-In-One Laser Printer
Fax Confirmation on a Canon MP830
To print a TX (transmission) report after each fax sent:
1. Press the Copy button if that light is not already lit
2. Press the Menu button
3. Press the Right arrow to get to "Maintenance / settings"
4. Press the OK button
5. Press the Right arrow to get to "Device settings"
6. Press the OK button
7. (You should be at FAX SETTINGS) Press the OK button again
8. Press the down arrow to get to "TX settings"
9. Press the OK button
10. Press the down arrow to get to "TX report"
11. Press the OK button
11. Press the down arrow to get to "Print for each TX"
12. Press the OK button
(You can have the machine print the first page of the fax with the report if desired)
13. Press Stop / Reset
Apr 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
88 people viewed this question
James Cagle
James Cagle
Jim Keysor
