I never asked for help with a computer, rather I asked for help with my pancake air compressor which will nmot build up any pressure and did not receivce an answer
could be a possibility. Clanking or rattling: Loose internal mounts can cause rattling and clanking from the compressor. The sound probably means that the motor has come loose and is moving around inside the sealed compressor can
first control non return check valve on the tank second the hose connections and pressure line tirth cilinder membrane or piston ring worn if an oilless compressor Usually under pressure control a pressure reliever which must be forced out of pressure, it may be that the pressure gauge does not close off
You need a qualified technician for the suction system need to be check and replaced if needed. There might some air leaks in the suction system. Thanks for asking FixYa.
