Question about Sony KP-57WS500 57" Rear Projection Television
I have a KP-57WS500 and when it is turned on the screen starts to turn blue and after a few seconds the entire screen is blue. After that happens the TV will turn off.
  • 18 Answers
This link has the instructions on how to fix this problem and other similar problems. You
have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection
TVs have the red, green, and blue pots in the same order as the picture that is listed on
this link, so you may want to google search for your model's service manual. The service
manual can also help you be able to remove the cover for your particular model of TV. I was
able to find the service manual for my model, and sure enough, the order of the pots are
reversed on mine, so I would have been adjusting the wrong color. Read all of the comments
on this link too, because you can find other helpful tips and may even find someone with the
same model of TV as you that gives more specific instructions for your model.
You may also find your model's service manual here:
http://esupport.sony.com/US/perl/index.pl
You can find information on Sony blink codes here:
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Blurry picture/adjust convergence
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C426085
I hope this helps you!
Fare well. :)
Iconoclast
P.S. You can also clean the mirrors and dry dust while you're in there which can help with blurriness and focus.
Posted on Jul 27, 2009
I have a 2002 KP-57WS500 sony tv. Whenever i turn it on, it is fine for about 5-10 seconds but then the whole screen slowly fades to blue until you see no picture but can still hear the sound perfecly. I...
Unfortunately, the Blue CRT will most likely need replacement. But you can get the entire assembly as a complete unit which makes it a easy removal and installation since the CRT is a complete one. Heres the link to that Blue CRT http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220790336974&ssPageName=STRK:MESE:IT
Jun 04, 2011 | Sony KP-57WS500 57" Rear Projection...
The screen on my Sony wide projection tv is turning blue after a few minutes. can you help? the model # is KP-57WS500
This is a typical bad CRT. The blue CRT part number is 8-733-647-25 but they are no longer available. It is not uncommon for this eventually to happen to the other CRT's as well. The only fix is to have a technician pull the defective CRT and have it sent to a company called VDC for rebuilding.
Nov 11, 2009 | Sony KP-57WS500 57" Rear Projection...
I have a KP-57WS500 when I turn it on goes blue...
Type in Sony Blinking Codes, you will find alist that tells you want each one means.
Aug 06, 2009 | Sony Televison & Video
Tv comes on for a few minutes then goes off
If you take off the front bottom panel of the tv wich is easy. Then you will see 6 tuning knobs at the bottom middle of the tv .the top 6 control contrast for the lights dont mess with those. the bottom 3 are the power to each light.red is bottom left if your screen went blue it makes sense that the red is starting to go but if you turn down the power to it left 1/8 turn it should fix it for awhile .Its easy.
Jan 01, 2009 | Sony KP-57WS500 57" Rear Projection...
KP-57WS500
I had this problem and at the same time I was getting blue tint. When the blue got darker, this would happen, Adjusted the voltage on the guns (3 screws in the front - lower panel off) and the blue went away and it stopped turning off. But later, it would start all over again. Same procedure, same fix.
Jun 24, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500
you need a new green CRT, sony has had some problems with the green and blue crts developing shorts . Let me know if you need further assistance.
May 09, 2008 | Sony KP-57WS500 57" Rear Projection...
KP-57WS500 TV FADES TO SOLID RED W/ LINES A FEW SECONDS AFTER I TURN IT ON
Red CRT is doing short circuit in the neck. You can try to open the front panel and to hit easy the neck with wood or something and to decrease the red screen a bit. If doesn't work then replace the CRT.
Jan 04, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
377 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
