Question about Microsoft Xbox 360 Console
Xbox 360 problems
Game wont go to the main screen evertime i push the power button it goes to the red light and read a error
  • 51 Answers
I had a similar problem, my 360's disc drive died and needed to be sent in for repair. Repairs are pretty quick, I got mine back in about 9 days.
Posted on Jul 27, 2009
Red light blinks and wont stay on when push power button
You can do this fan test.
Turn the main switch off, hold the eject button.
While holding the eject button, turn the main switch on, when the power light is green, release it and you should hear a beep.
The fan will operate at the highest speed possible and will eject any disc that is inside.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and the red light will blink. When this happens, turn the main switch off and on then turn it on normally.
Tell me how this goes!!
May 05, 2011 | Sony Playstation 3 (PS3) Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Red light come on xbox360 what is the problem
If you get red light around your xbox power button the you have red ring of death. This is when your Xbox has overheated. While im not all that famlier with Xbox I have read there is a 6 cent fix (cause you use 6 pennies) You would have to read up because as I sid before not great with Xbox. I'm sure microsoft would do it to but hey if you good with tools 6 cents sounds pretty cheap.
Im sorry for your loss
Good Luck and Happy Gaming-Koscoe
Oct 13, 2010 | Video Game Consoles & Games
One red light on the bottom right on the power button
XBOX 360 Red Light error, or Red ring of Death RORD is a very common issue, and can happen anytime. There are different Error numbers related to RoRD, and appears on screen starting with "E".
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console.
click here to download repair guide......
Oct 07, 2010 | Microsoft Xbox 360 Console
My xbox360 has one red light flashing
1 red light usualy means hardware failure. There is another error code you can get of of xbox. While machine is on push the the sync button on console and while sync is pushed in press eject button. The lights on the console will give you youre first digit. Theres 4 in total. Repeat pressing the sync and eject button till you have got the four digits and console is back to the red light.
When getting codes the lights will light up. 1 red light means 1 2 means 2 and so on. 4 red lights means 0. Let us know and ill get back to you.
Apr 05, 2010 | Microsoft Xbox 360 Console
If got a red flashing light where the on button is and it says on th screen system error contact xbox customer support????????????????
hello Sir
Xbox 360 Repair – Want To Beat The Red Lights And Get Back To Gaming? Read This! If you are looking for a way to repair your Xbox 360 from home without having to wait for 4 weeks and have to pay out a lot of money for repair then this blog post will tell you how to do this.
You see the problems are caused by overheating and the main problem is the Xbox 360 3 red lights however you may also get disc reading problems, freeze ups, 2 red lights and 1 red light error codes as well.
So if you get these problems what can you do to perform Xbox 360 Repair?
Well you can send it in and they will repair it for you however this will take about 4 weeks and cost you money for the repair as stated above.
What a lot of gamers are doing is taking the matter into their own hands and performing Xbox 360 Repair from home.
Now this sounds a lot more difficult then it actually is and and as long as you stop the heat build up you will be able to play your games.
To do this you can use a good Xbox 360 Repair guide that will show you how to stop these errors from home and the best thing is that all you need is a few household items.
There is an Xbox 360 Repair guide that will give you step by step videos and a full walk-through for all of the errors so all you need to do is follow through and you will be able to perform Xbox 360 Repair at home with ease!
Check out the full guide and see how easy it is to fix:
Xbox 360 Repair
Sep 26, 2009 | Microsoft Xbox 360 Console
Xbox 360
What is the error code at the bottom of the screen & check for flashing red lights on the power button if 3 illuminate it the infamous RROD(Red Ring of Death-google it) which you will get a free repair for if its the bottom right quadrant flashing red then its most probably E74 or E61. E61 is a hard drive related problem so try playing without it, & E74 is the AV cable snapped inside or the GPU/CPU inside the xbox 360 has weak solders on it, I suggest MS support ASAP.
Jul 22, 2008 | Microsoft Xbox 360 Console
4 red lights flashing
The TV screen or monitor remains black when you start an Xbox 360 console.
This behavior may occur with or without a game disc in the disc tray. The console appears to be on because the green power light illuminates and the fan continues to operate. However, the screen remains black.
Click on the IMAGE i paste here below:
Thank you,
~micro
May 21, 2008 | Microsoft Xbox 360 Console
Wont read X BOX 360 disks
Go to Best Buy and exchange it for a new one.
Mar 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
37 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
