SOURCE: I cannot get a full cup of coffee from my Keurig
I HAD A SIMULAR PROBLEM...AFTER DESCALING WITH VINIGAR I NOTICED THAT MY COFFEE CUP WASNT ALWAYS SERVED FULL....THEN AFTER A LITTLE DIGGING ON THIS SITE IT BECAME OBVIOUS....I HAD A PIECE OF SOMETHING STUCK IN THE ONE WAY VALVE...SO TO SOLVE THIS I DISCONECTED MY KEURIG,BROUGHT IT OUT TO MY SHED AND CAREFULLY BLEW OUT THE THE ENTIRE UNIT WITH MY AIR COMPRESSOR BEING CAREFUL NOT TO USE TO MUCH PRESSURE AND BLOWING OUT A SEAL.....BROUGHT IT BACK IN,FIRED IT UP,WORKS PERFECT AGAIN...EVEN THE DESCALE LIGHT NOW STAYS OFF.NO MORE PINCHING THE RUBBER RETURN VALVE IN THE RESIVIOR JUST TO BREW A CUP OF COFFEE. HOPE THIS HELPS SOMEONE........................
SOURCE: mini brewer shuts off wont heat up wont make
thow it on the ground and stom on it. if its not working now theres nothing you can do. Take it to the dump
SOURCE: keurig coffee maker does not make a full cup,
Check the needle to make sure it's not clogged. You can completely remove the k-cup holder and wash it out with your kitchen sink sprayer to help remove any obstructions. The manufacturer even recommends using the tip of a small paper clip to help push out any debris if needed. Then try brewing a cup of just water on the largest setting without a k-cup in it. Hope that helps! Best of luck...
SOURCE: keurig coffee maker makes loud noise single cup
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
SOURCE: need directions for the Micro-Perk microwave coffee brewer
i recently bought a microwave coffe maker and it also has no instructions,,, help its from a company called colony...
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
heatman101
heatman101
Keurig
heatman101
Keurig
heatman101
heatman101
l[]][\
Keurig
heatman101
heatman101
=0=0
heatman101
l;p0=,/.,./
heatman101
l;;'l
