Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
F10 error code
Ok its the night before Thanksgiving. I have burned 3 pies (15 minutes into cooking) the beeping and F10 error code come up. Please tell me what I can do to fix this problem in the middle of the night.
Thank you!
  • 1 more comment
  • P0LLy Nov 24, 2007
    Thank you for trying to help. For whatever reason it started working again on its own AFTER I took the turkey to my daughters to cook. Used the oven to cook all the side dishes.
    Thank you again.
  • weaver7 Oct 27, 2008
    the F10 error code comes on after around 10 minutes of baking. I have a Kenmore Electric Range model 790.9611, 9612, 9613 that is only around 2 years old. What could be the problem?
  • Anonymous Mar 31, 2014
    F10 error code-beep won't stop.
  • 248 Answers
Need model number please. It should be behind drawer on left or right.
Posted on Nov 22, 2007
My frigidaire stove I have to umplugg it because keeps beeping f10 can' stop I push any bottom and keeps beeping
Hi Elizabeth! From what you have posted, your appliance is experiencing a high-temperature error code (F10). A high-temperature error indicates that your oven has reached too high of a temperature for too long of a time period. If unplugging your appliance does not prove to be successful, you would require a visit from a professional to check the temperature sensor and the electronic oven control (brains of your appliance behind the touch pad). If you have any other questions please comment so I can help!
Dec 18, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
F10 code after frigidaire wall oven on for 15 minutes
Good Morning Dave, thank you for allowing me to assist you!
If you are getting error code F10, it typically means that your range is experiencing an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to your range by either unplugging it or flipping the household circuit breaker off for about ten minutes. If the error code persists, I would be advisable to reach out to a professional to proceed further. Most likely the RTD (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
Nov 21, 2013 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire beeping with F10 signal
sounds like you need to get all food out and switch it off and leave the doors open and leave it for two days with the doors open ok then afther you have left it swich back on with doors closed do not open doors for 24 hours swicth on ok then it should be ok if not then its lack of gas
Oct 15, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven is flashing f10 and burning the top of food being cooked and then shuts itself off
Hello - Typically error code F10 indicates a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 13, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My frigerdaire oven heats for a while about 15-30 minutes then shuts down with a beeping noise and a f3 code.
Good Afternoon Friend,
I see that your Frigidaire double oven heats up for about 15-30 minutes, then shuts down and begins beeping while showing an F3error code. The F3 states that the oven is sensing a potential runaway temperature. This is possibly a sensor issue or it could be a false error code.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Let the oven heat up, and if you are still receiving an F3 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
Jan 27, 2012 | Frigidaire 30 in. Electric Gallery Series...
Digital display is reading F10 and beeping and the oven shuts off after burning Banana Bread I also had smoke coming out the back panel of the stove top
The F10 error code means that a button on the touchpad is stuck.The error code can be cleared by pushing the cancel/off button and if the F10 returns the clock needs to be replaced since on that model the touchpad is part of the clock.
Sep 23, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I used the self clean cycle and it has cooled off now getting error F5E1 and won't unlock? Please help. I use my oven almost daily!!
F5-E1 is a door lock error. Depending on the extent of the error, a hard reset may recycle the door lock and allow you to use the oven. Turn off power to the oven for 2 to 5 minutes and then turn the power back on. Give the oven about 2 to 3 minutes to possibly reset.
If the error code returns, there a few different problems you may have.
  1. The door latch mechanism could be broken or shorted
  2. The may be a pinched or shorted wire
  3. The Oven Control Unit may be bad
If further assistance is needed, please submit the brand and model # of your oven
Apr 15, 2011 | Ovens
Burners light ok, oven will not light
Stop time knob needs to be out; you set it for timed bake. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Viking Electric oven beeping saying EOCGT v36 premiere poweringup
Sounds like leaving the door open has possibly cooked the controller. I would try a power cycle - power off at fuse for 5 minutes, then reapply power. If this doesn't clear it, you may need a new controller for it.
Nov 27, 2008 | Ovens
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
1,601 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
